It is currently Wed Aug 13, 2025 7:54 am
 Post subject: What coil should I use.
PostPosted: Mon Nov 05, 2012 10:12 pm
Greetings all.
Went to Mini's at the Mill yesterday. What a hoot!
Anyway, It was a hot day (bloody hot) A couple weeks back I was trying to track down a fault in my ignition. Sure enough, half way through the Adelaide hills it started to backfire and died. Wriggled the fuse and it seemed to go for a while. Did this every couple of miles. Put a new fuse in. Seemed good on the way home, then trouble again. Mmmmmmmmmmm.....fuse box?
Put a new one in tonight. Ahhh..... still stops after a couple hundred yards.
I'm thinking it's gotta be the coil. I put in a set of those electronic points a couple months back. Was running the GT40 coil that came with the car. What is the best suited coil to buy?
I new believe it was the coil all the time. Some coils have a R rating (resistor?)
Alex.
PostPosted: Mon Nov 05, 2012 11:05 pm
Standard gold Lucas one will be fine.
Are you running points still?
Check your points gap.
And condensor.
You'll be sorted for 60 bux and have a good ignition for the next MATM.
Great to see your car up there.
And congrats on the trophy win!
PostPosted: Mon Nov 05, 2012 11:18 pm
Thread hijack....we won first prize for the Blue & Yellow Clubman in Competition Class.
Makes it 1st,2nd & 2x3rds from 4 MATM.
1974 1150cc Leyland Mini S racer,
1975 No motor Leyland Mini "ute"
1991 IPRA Honda Integra (in the build)
1995 Land Rover Discovery 300Tdi
CAMS Scrutineer
PostPosted: Tue Nov 06, 2012 6:34 am
Thanks willy.
I'll grab one today. It was a great day. Had to leave it in my sisters shed at Clarence Park, as I wouldn't have made it up Darlington hill. It was in her yard, but I tried the fuse box, then put it in the shed due to the storm hail warning.
And well done DA9jeff. Saw yours there.
Users browsing this forum: No registered users and 277 guests
