Greetings all.
Went to Mini's at the Mill yesterday. What a hoot!
Anyway, It was a hot day (bloody hot) A couple weeks back I was trying to track down a fault in my ignition. Sure enough, half way through the Adelaide hills it started to backfire and died. Wriggled the fuse and it seemed to go for a while. Did this every couple of miles. Put a new fuse in. Seemed good on the way home, then trouble again. Mmmmmmmmmmm.....fuse box?
Put a new one in tonight. Ahhh..... still stops after a couple hundred yards.
I'm thinking it's gotta be the coil. I put in a set of those electronic points a couple months back. Was running the GT40 coil that came with the car. What is the best suited coil to buy?
I new believe it was the coil all the time. Some coils have a R rating (resistor?)
Alex.
