Fixing leaking petrol caps https://www.ausmini.com/forums/viewtopic.php?f=2&t=79107 |
Author: | AWOODY [ Tue Nov 06, 2012 6:15 pm ] |
Post subject: | Fixing leaking petrol caps |
Is there a way to fix leaking petrol caps the non locking chrome type. |
Author: | mini_mad_matt [ Tue Nov 06, 2012 6:17 pm ] |
Does the seal have much pressure on the filler neck when you screw it on? |
Author: | Morris 1100 [ Tue Nov 06, 2012 6:22 pm ] |
The problem is usually the tank and not the cap. Drmini cut the neck off his tank and fitted a repair kit ![]() |
Author: | drmini in aust [ Tue Nov 06, 2012 6:26 pm ] |
Yeah I rinsed the tank a few times with hot water, then filled it with cold water to the bottom of the neck while I oxy welded it. The weld is inside the rubber grommet so can't be seen. |
Author: | Bubbacluby [ Tue Nov 06, 2012 6:34 pm ] |
Often the cork seal is crushed and doesnt allow it to seal. Get the centre from the chest cover cork gasket from a small bore gasket kit and cut a new one seal for your cap. initally it will be tight but it wears in. The cooper s chest-cover cork is too thick. Brenton |
Author: | drmini in aust [ Tue Nov 06, 2012 6:45 pm ] |
Many tanks have damaged bayonet lugs in the top (or the sealing face bent) from bogans levering locking caps off to pinch fuel. Neoprene rubber is a better seal than cork, which tears up from the cap being turned. You can buy the right size neoprene seals at a boat shop (they are used on S/S cruisetanks, which take the same cap size as a Mini). ![]() [edit] I'm talking Mini sedan tanks here, your woody's neck may be different diameter (I've never measured one). |
Author: | John Smidt [ Tue Nov 06, 2012 7:10 pm ] |
mini king have genuine replacement seals in stock |
Author: | AWOODY [ Tue Nov 06, 2012 7:33 pm ] |
Thanks for the tips , Doc I sold the woody about 3 yrs ago now I have just finished a replica S , see the event photos for the mitg run last weekend, the caps are old so your solution or Johns are the go ,thanks. |
