It is currently Tue Jul 29, 2025 1:24 pm
PostPosted: Wed Nov 07, 2012 4:40 pm
I've got a bit of play in one of my rear swing arms. What's involved in refusing these? What parts do I need and how should I go about doing it?
Cheers, Matt
Don't be fooled, Gruhms is not my real name.
PostPosted: Wed Nov 07, 2012 6:05 pm
You need a repair kit. Available from the usual suspects.
It contains:
1x new shaft,
1x new needle bearing (for inner end)
1x new bush (for outer end)- undersized bore, needs reaming
1x plastic grease retainer sleeve (bin it if you still have original steel ones in there, they don't warp or split)
Difficulties:
pulling the old needle bearing out (unless you have the right puller)
driving the old bush out
reaming the bush, aligned with the needle bearing (you need a piloted reamer)
Easiest method- take it to Greig @ Mini Classic, or Mini King. :wink:
PostPosted: Sat Nov 10, 2012 7:58 am
Like this.
http://www.minispares.com/product/Class ... .aspx|Back to shop
Users browsing this forum: Goldbrocade_62 and 110 guests
