It is currently Tue Jul 29, 2025 1:30 pm
 Post subject: Removing Glued On Carpet
PostPosted: Fri Nov 09, 2012 8:59 am
Hi, I have the lovely job ahead of me trying to get all the carpet out of my shell, it has been stuck on with that thick contact adhesive, and it is a real pain in the @ss to get off.
I was wondering if anybody knew a product that dissolves of softens it, or if you have an easy way of getting the carpet off. If not I will continue to chip away with a screwdriver and scraper.
Dave
PostPosted: Fri Nov 09, 2012 9:39 am
You could try a heat gun to soften the glue. If you aren't worried about keeping the carpet, its possible acetone will dissolve it.
They didn't work for me, I had to use a wire wheel in a grinder.
:lol:
PostPosted: Fri Nov 09, 2012 10:10 am
Must be the same glue that I have. I think they glued the carpet down so nobody could see the rust underneath. My next carpet will be removable so I can see if any water gets in and if it does I can dry the carpet and fix the leak. I think I will tackle mine with the wire wheel too.
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Fri Nov 09, 2012 10:15 am
If you have the right carpet you don't need glue. The moulded stuff fits fine and is retained enough from the various things that poke through like seat brackets.
If its a multiple piece carpet, just use double sided tape or water based glue.
At least then when the carpet comes unstuck you know its because its wet making the cleanup easier! :lol:
PostPosted: Fri Nov 09, 2012 10:28 am
Yeah not worried about the carpet, I guess i will keep going as i am, but i might try acetone, see if it helps. thanks for the help.
Dave
PostPosted: Fri Nov 09, 2012 5:21 pm
Be careful with acetone though.
http://www.ehs.utoronto.ca/resources/wh ... mis11d.htm
PostPosted: Fri Nov 09, 2012 8:00 pm
heat gun melts the glue
PostPosted: Sat Nov 10, 2012 7:27 am
acetone will take glue off...........and paint. If its normal contact cement, spray liberally with turps, carpet should come off with blunt scrapper the next day.
PostPosted: Sat Nov 10, 2012 8:30 am
Thanks peterb
Dave
