Rebushing rear swing arms
https://www.ausmini.com/forums/viewtopic.php?f=2&t=79120
Author:  gruhms [ Wed Nov 07, 2012 4:40 pm ]
Post subject:  Rebushing rear swing arms
I've got a bit of play in one of my rear swing arms. What's involved in refusing these? What parts do I need and how should I go about doing it?
Author:  drmini in aust [ Wed Nov 07, 2012 6:05 pm ]
You need a repair kit. Available from the usual suspects.
It contains:
1x new shaft,
1x new needle bearing (for inner end)
1x new bush (for outer end)- undersized bore, needs reaming
1x plastic grease retainer sleeve (bin it if you still have original steel ones in there, they don't warp or split)
Difficulties:
pulling the old needle bearing out (unless you have the right puller)
driving the old bush out
reaming the bush, aligned with the needle bearing (you need a piloted reamer)
Easiest method- take it to Greig @ Mini Classic, or Mini King. :wink:
Author:  peterb [ Sat Nov 10, 2012 7:58 am ]
Like this.
http://www.minispares.com/product/Class ... .aspx|Back to shop
