Looking for someone who can fit a Rover dashborad please https://www.ausmini.com/forums/viewtopic.php?f=2&t=79163 |
Author: | roverminifan [ Mon Nov 12, 2012 9:39 am ] |
Post subject: | Looking for someone who can fit a Rover dashborad please |
Hi Guys, I originally was a member under my old user name cooper93 but could not log in anymore. So Hi again. ![]() I have an original Dashboard ( brush metal finish ) that I would love some help fitting. Been quoted silly money by professional shops so was wondering if anyone could help me ? Im happy to pay for your time in Cash, beers or whatever but it would need to be reasonable. Car is a 1993 Rover Mini Cooper works SPI Many thanks in advance Garth |
Author: | tomtom [ Mon Nov 12, 2012 9:50 am ] |
Post subject: | Re: Looking for someone who can fit a Rover dashborad please |
roverminifan wrote: Hi Guys,
I originally was a member under my old user name cooper93 but could not log in anymore. So Hi again. ![]() I have an original Dashboard ( brush metal finish ) that I would love some help fitting. Been quoted silly money by professional shops so was wondering if anyone could help me ? Im happy to pay for your time in Cash, beers or whatever but it would need to be reasonable. Car is a 1993 Rover Mini Cooper works SPI Many thanks in advance Garth Might want to post where you are located ![]() |
Author: | roverminifan [ Mon Nov 12, 2012 9:56 am ] |
tomtom wrote: roverminifan wrote: Hi Guys, I originally was a member under my old user name cooper93 but could not log in anymore. So Hi again. ![]() I have an original Dashboard ( brush metal finish ) that I would love some help fitting. Been quoted silly money by professional shops so was wondering if anyone could help me ? Im happy to pay for your time in Cash, beers or whatever but it would need to be reasonable. Car is a 1993 Rover Mini Cooper works SPI Many thanks in advance Garth Might want to post where you are located ![]() Whoops --- ![]() |
Author: | Harley [ Mon Nov 12, 2012 10:09 am ] |
They aren't hard to fit at all - only 3 screws, the plug for the radio, plug for speedo and speedo cable. With the steering wheel off its a one man job. You can't go too wrong if you have a crack yourself. Whats the difficult part? Did your car have the dash originally? |
Author: | roverminifan [ Mon Nov 12, 2012 10:29 am ] |
Harley wrote: They aren't hard to fit at all - only 3 screws, the plug for the radio, plug for speedo and speedo cable. With the steering wheel off its a one man job.
You can't go too wrong if you have a crack yourself. Whats the difficult part? Did your car have the dash originally? Thanks for the reply - Well, I may give it a go then. The thing is, the dashboard does not come with any fitting hardware ( its new old stock ) so I would love to see a how to and what I need before tackling it. My car has a dashboard fitted ( its the plastic one some Japanese Cooper had fitted around 93-94 ) but I really want to fit this one ( same as fitted to Mini 40s ) to finish the car off... any link you know of that shows how to do it ? The haynes manual shows it but I need more pictures ![]() |
Author: | Harley [ Mon Nov 12, 2012 10:44 am ] |
I think the thing to do is remove the old dash and see if the mounting brackets are the same. Does your car have AC? |
Author: | roverminifan [ Mon Nov 12, 2012 10:48 am ] |
Harley wrote: I think the thing to do is remove the old dash and see if the mounting brackets are the same.
Does your car have AC? Yes it does - Thats actually a good point, as the brackets could be reused to fit the new dash. Strangely enough, my glove box on the new Mini 40 dash is not fitted nor includes any hardware eather... I remember seeing the hardware kit in mini spares site so I better order that first. |
Author: | Harley [ Mon Nov 12, 2012 10:52 am ] |
The other thing to check is the air vents - some of those plastic dashes have the vents one above the other or behind the glove box door. Are they in the same spot as the air vents in the new dash? |
Author: | roverminifan [ Mon Nov 12, 2012 10:57 am ] |
Harley wrote: The other thing to check is the air vents - some of those plastic dashes have the vents one above the other or behind the glove box door. Are they in the same spot as the air vents in the new dash?
Yes you right but luckily both are in the same spot. |
Author: | IwannaMini [ Mon Nov 12, 2012 11:40 am ] |
When do you want to do it? I have a Rover with air con with what I think is the same dash. I have to pull mine out as the wiring needs to be redone. If you want I can either send pics of it out, or you can pop by and check it out to see the mounts etc? I am located in West Ryde in Sydney. |
Author: | roverminifan [ Tue Nov 13, 2012 8:38 am ] |
IwannaMini wrote: When do you want to do it? I have a Rover with air con with what I think is the same dash. I have to pull mine out as the wiring needs to be redone. If you want I can either send pics of it out, or you can pop by and check it out to see the mounts etc? I am located in West Ryde in Sydney.
Hi Mate, that would be very helpful indeed. Happy to drop around . Can you please PM me you number and I will give you a call. Thanks ![]() |
Author: | mini1990 [ Tue Nov 13, 2012 8:00 pm ] |
Im in Mona Vale on the Northern Beaches. Give us a shout if you need a hand? |
Author: | roverminifan [ Thu Nov 15, 2012 1:30 pm ] |
Thanks guys ! Will be in touch as soon as the DB hardware gets here. ![]() |
