Drum Brake Overhaul - Shopping List
https://www.ausmini.com/forums/viewtopic.php?f=2&t=79204
Author:  bigtez [ Fri Nov 16, 2012 4:32 pm ]
Post subject:  Drum Brake Overhaul - Shopping List
I am going to replace my standard drums with stepped drums and am wondering if I have everything I need to complete the job. Wheel bearings seem to be in good condition, but should I just replace them anyway while I have the flanges off? Here is the list, with Karcraft part numbers and quantities required.
Rear Brakes Part Number Quantity
Drums Cooper S 21A1279 2.00
Brake Shoes GBS834AF/2 1.00
Wheel Stud 2.300" 21A1278 8.00
Shoe Spring Kit GBK1834 1.00
Wheel Cylinder Rear 0.750" GWC1102/1 2.00
Screw Brake Drum - Cooper S CMZ422 4.00
Front Brakes - Drums
Brake Shoes GBS733AF 1.00
Wheel Stud (x8) 21A1278 8.00
Shoe Spring AAU8243 4.00
Spring - Shoe to Cylinder 27H3753 4.00
Wheel Cylinder LHF 15/16" GWC127 2.00
Wheel Cylinder RHF 15/16" GWC126 2.00
Is there anything I have missed?
Terry
Author:  michaelb [ Fri Nov 16, 2012 5:26 pm ]
What are your front brake hoses like?
But all else looks Ok
You shouldn't need to remove the hubs as you can juggle the brake cylinders in and out around the hub
Author:  bigtez [ Fri Nov 16, 2012 9:11 pm ]
Hoses look as though they have been replaced fairly recently. Will give them a good clean and inspection while I have good access to them though, just to be sure.
Author:  VulcanBB18 [ Fri Nov 16, 2012 9:17 pm ]
How are the ball joints? If they're getting a bit sad now would be an ideal time to tackle them.
I thought I saw somewhere you can get tapered roller bearings for drum brake hubs, if you needed bearings might as well upgrade :)
just some thoughts.
cheers,
Jacob
Author:  drmini in aust [ Fri Nov 16, 2012 9:56 pm ]
Tapered roller bearing kits (as used on disc hubs) also fit in drum hubs. But note the split spacer ring between the inner seal (against CV) and the bearing cup is wider than the ball bearing type one. This ring keeps the seal from fouling on the bearing cone. If you don't have the wider ring, just don't knock the seal in too far.
