It is currently Fri Aug 15, 2025 1:41 am
 Post subject: Heating trouble
PostPosted: Fri Nov 23, 2012 7:56 pm
Guys I have heating issues I've got a alloy radiator off eBay :) and a new water pump if i go around my block once from a cold motor to nearly over heating when I pull in my driveway haven't got water in oil or oil in water (yet) wat are your thoughts blown head gasket ??? Happen all of a sudden was running fine
PostPosted: Fri Nov 23, 2012 8:00 pm
Thermostat?
PostPosted: Fri Nov 23, 2012 8:05 pm
It is working if u watch the gauge the needle drops when it opens then just over heats
PostPosted: Fri Nov 23, 2012 8:22 pm
timing/fuel issue for sure...
(too lean or too advanced or both)
cheers,
Jacob
PostPosted: Fri Nov 23, 2012 8:34 pm
Checked timming it hasn't moved and it runs starts revs very nicely isn't blowing any smoke
PostPosted: Fri Nov 23, 2012 8:58 pm
Check water is flowing. Knew a block who found a peice of rag under his thermostat. It was forgotton when he plugged housing for painting motor.
