It is currently Fri Aug 15, 2025 3:42 am
 Post subject: Sump plug washer
PostPosted: Fri Nov 23, 2012 9:26 am
any ideas on what size and best types to use?
I'm gonna do an oil change as the matic is still leaking a oil from round there somewhere so thought I'd replace the washer also whilst there
PostPosted: Fri Nov 23, 2012 3:02 pm
It's just an annealed copper washer, 5/8" bore.
You could use red fibre but it's not as durable.
It might be coming from the shift cable connection near the plug, old autos tend to drip there a bit.
PostPosted: Fri Nov 23, 2012 4:33 pm
thanks Doc
I didn't get around to doing it just yet anyways - too busy elsewhere!
I grabbed a multi size copper washer pack from supercheap and will have a go tomorrow.
Is the shift cable plug under the gearbox there? I think I know where you mean, but I do think it is the sump plug as its the same old plug washer from bugger knows when I believe!
PostPosted: Fri Nov 23, 2012 5:53 pm
Probably work hardened if it is copper, preventing it from deforming and sealing properly. Better off with a new one but if you get stuck you could anneal it.
PostPosted: Fri Nov 23, 2012 6:08 pm
To anneal it, you heat it red hot on a brick with a gas torch, and then drop it edge on into water. Result = dead soft.
PostPosted: Fri Nov 23, 2012 10:16 pm
I use red fibre ones on my sump plug..
Gets replaced every time the oils changed..
Never had a problem with them. :wink:
Cheers,Rhys
1977 Leyland Mini Van - Sold
Users browsing this forum: Bing [Bot] and 266 guests
