Running like a bag of ..... https://www.ausmini.com/forums/viewtopic.php?f=2&t=79287 |
Author: | 1275LS [ Fri Nov 23, 2012 9:32 pm ] |
Post subject: | Running like a bag of ..... |
So I did an oil change the other weekend and probably overfilled the oil a bit. So I'll drain it tomorrow and get the level right but it has gottent too hot the last couple of times I have driven it and is running really rough. Also there is a bit of water around when I stop but I am not sure if thats just because the thing has gotten too hot or a hose is done. It has recently had a recore to the rad and has been fine since so I dont think it is an issue there. It was due to go in to Matt Read for a carby rebuild so is the overheating more likely to be to do with whcih of the following:
Carby needs rebuild and adjustment Hose leakage Timing etc Any ideas welcome. Tomorrow I'll be:
Sorting the oil level Checkling the plugs Checking the timing is still on (SimonBBC electronic dizzy should still be ok) Double checking the rad recore hasn't failed Anyway I hope I haven't left anything out and at least given someone a chuckle with my over-tired ineptitude. ![]() |
Author: | i got a mini [ Fri Nov 23, 2012 9:37 pm ] |
Check all radiator hoses u might be loosing water which is causing u to overheat ![]() |
Author: | Bubbacluby [ Fri Nov 23, 2012 9:59 pm ] |
Check to see if your oil is milky, or your water has oil in it. If it has gotten very hot you may have blown a head gasket also. But first start it and run it looking under the bonnet and revving it will increase the water pressure and if it is a hose you should see it squirting out, pouring out on the floor. This happened to me on holidays when i was in brisbane. Ran fine all the way there, all of a sudden was getting hot and didnt know why and thought radiator had kicked it in. Checkled it out when i could see and the heater outlet on the rear radiator pipe had split (Luckily i brung a spare with me) Good luck |
Author: | 1275LS [ Fri Nov 23, 2012 10:37 pm ] |
Thanks guys. Will check it over in the am. Hey Bubba are you ready to sell me your spare GT yet ![]() Just kidding... the wife would kill me... |
Author: | BALLISTIC [ Fri Nov 23, 2012 10:48 pm ] |
Did you bleed the cooling system (thermostat opened) after refitting radiator? (check temp & pressure/firmness of top & bottom hoses after operation for an indication) Is temp sender giving false reading? Is gauge/indicator operating correctly? Was coolant put in the cooling system when refilled or did you only use water? Is carb running lean? At back of cylinder block there is a drain plug, is it blocked when you remove plug? Comp test? Water pump & or bearing? Belt tension? Radiator leak? top/bottom Hose leak? Bypass hose leak? Heater? if so check it is getting heat/hot in cabin. |
Author: | 1275LS [ Sat Nov 24, 2012 12:05 am ] |
Great list Ballistic thanks
Is gauge/indicator operating correctly? Yep I'd say so Was coolant put in the cooling system when refilled or did you only use water? Coolant Is carb running lean? Either or - it needs a rebuild At back of cylinder block there is a drain plug, is it blocked when you remove plug? Never knew of that one... will have a look Comp test? Fine last time I checked. Will do again tomorrow Water pump & or bearing? I put in a new hiflow one when I recored the rad Belt tension? ok i think.. will check Radiator leak? not that I could see. its a recent recore. I'll check top/bottom Hose leak? possibly. there was some coolant there but I couldn't see if it had just dripped off the cap Bypass hose leak? I hope not, dont feel like pulling the head or the rad Heater? if so check it is getting heat/hot in cabin. Currently in a box in the shed so I doubt it ![]() Thanks again. |
Author: | TheMiniMan [ Sat Nov 24, 2012 2:59 am ] |
righty-o Alec,,, bring it over,,, i know you need a good spanking ![]() ` i`m ok to do it now,,, my spastic-ness has all gone ![]() seriously guys-n-gals ,,, Alec just loves the attention, ![]() Edit--> seriously it`s obvious it needs a good looking at... i`m only joking with the spanking & the "Alec wanting the attention" thing,,, that was just me being silly really ![]() ![]() |
Author: | 1275LS [ Sat Nov 24, 2012 7:57 am ] |
TheMiniMan wrote: righty-o Alec,,, bring it over,,, i know you need a good spanking
![]() ` i`m ok to do it now,,, my spastic-ness has all gone ![]() seriously guys-n-gals ,,, Alec just loves the attention, ![]() Edit--> seriously it`s obvious it needs a good looking at... i`m only joking with the spanking & the "Alec wanting the attention" thing,,, that was just me being silly really ![]() ![]() Thanks Matt. |
Author: | 1275LS [ Sat Nov 24, 2012 10:29 pm ] |
Ok here's the verdict. The bottom hose's top joint was not done up properly and leaking The heater take off has a dodgy stud an isn't sealing. It was also pretty murky.. so I gave it a flush. When it gets round to a rebuild it'll get hot tanked I guess.. Thanks all. |
