Thermo fan switching
https://www.ausmini.com/forums/viewtopic.php?f=2&t=79301
Author:  Fiji [ Sun Nov 25, 2012 7:59 am ]
Post subject:  Thermo fan switching
I have a thermo fan fitted with a manual switch & relay incorporated mounted under dash.
Question is.,, I would like to change it to a temperature controlled switch from the radiator.
Me thinks that all I really need to do is run the relay to the temp switch mounted in my radiator instead of the manually mounted one to the fan . Should be pretty simple. ??
Author:  Kermit [ Sun Nov 25, 2012 8:21 am ]
Yeah it's easy. I haven't done it to my mini yet but I fitted one to another Car I have and you just run an accessories wire to the thermo switch and then run that to the part that turns the relay on and off, make sure you put a fuse on the wire to the battery also cos I found that they draw a lot of amps and tend to want to melt wires if you don't. Hope that helps :)
Author:  MiniVLT [ Sun Nov 25, 2012 11:27 am ]
If your melting wires then you've run the wrong gauge wire. You need a bigger / thicker conductor.
A fuse protects the wiring, not the component on the end.
Thermo fans will run constantly at 8 or so amps, depending on size, and startup current can be double the running current!
Cheers Shane
Author:  Kermit [ Sun Nov 25, 2012 5:25 pm ]
Yeah all good I was running 2 off of one wire, a mate wired it for me I wasn't aware of it till it was too late. Fixed now though
Author:  mini1990 [ Mon Nov 26, 2012 8:05 am ]
My suggestion would be to buy the Craig Davies electronic fan switch. Basically its a probe that goes between the fins of the radiator. After 3 different attempts and mechanical switches and so forth I found this one to be the best.
You can adjust the temp it turns on with the relay provided in the kit. Basically you need to hook the relay to power, ignition, the fan, earth and the probe itself. Pretty simple really.
Author:  Fiji [ Mon Nov 26, 2012 5:52 pm ]
Thanks I'll look it up.
With a relay already installed to the under dash switch I'll just swing the wiring over to the thermo switch
Author:  awdmoke [ Mon Nov 26, 2012 6:12 pm ]
Jaycar kit is a much cheaper option:
http://www.jaycar.com.au/productView.asp?ID=KC5381&CATID=25&keywords=&SPECIAL=&form=CAT&ProdCodeOnly=&Keyword1=&Keyword2=&pageNumber=&priceMin=&priceMax=&SUBCATID=347
Has adjustable temperature switching and importantly adjustable hysteresis
Author:  Fiji [ Mon Nov 26, 2012 6:13 pm ]
Fark I was there fixing my downlights today didn't even think .
Solid cheers
