It is currently Mon Aug 04, 2025 12:44 pm
 Post subject: Front cam bearing
PostPosted: Mon Dec 03, 2012 3:03 pm
Got my block back from the engine builder but I think the front cam bearing is in the wrong way. Am I right in saying that the big long hole goes on the bottom that is the oil feed that comes from the crank main bearing and the small hole goes on top which is the feed to the rockers?
1963 Morris 850
 Post subject: Re: Front cam bearing
PostPosted: Mon Dec 03, 2012 3:29 pm
yes that is correct. I just checked a block that GR fitted cam bearings to last week.
PostPosted: Mon Dec 03, 2012 3:37 pm
Thanks for that, much appreciated. My front cam bearing is in upside down then. Back to the engine builders.
1963 Morris 850
