Seat questions https://www.ausmini.com/forums/viewtopic.php?f=2&t=79337 |
Author: | Dylans Clubby [ Tue Nov 27, 2012 4:20 pm ] |
Post subject: | Seat questions |
Good afternoon all The seats in my mini (and the door cards, now that I think of it) are a little worse for wear. The back seat feels fine, but there's a bit of a rip in the dot-cloth. The front seats are under covers, but i know they are FILTHY, and they seem to be caving in when I sit on them. Old foam I suppose. So my questions are: 1. I'm going to give them a clean first and see how they come up. Product suggestions? I have the dot-cloth inserts, tips on cleaning this? 2. Can the foam be redone without having to re-trim the outside? Or, any other ideas as to why the seats feel like they have lost their pizzaz? 3. If i do need to retrim the seats, the dot cloth is supposed to be hen's teeth, isn't it? Has anyone had any luck with reproduction stuff? Cheers! |
Author: | frednutz&co [ Tue Nov 27, 2012 4:38 pm ] |
have a look at the rubber diafram under the seat |
Author: | MrFail [ Tue Nov 27, 2012 5:49 pm ] |
+1 for checking the rubber diapham underneath. If they are broken the seat will feel saggy. If you need some i have 2 brand new ones sitting here. ![]() |
Author: | womble99 [ Tue Nov 27, 2012 6:40 pm ] |
So are there only the rubber diaphragm ones available now? Mine have a wire spring base? |
Author: | frednutz&co [ Tue Nov 27, 2012 6:53 pm ] |
[quote="womble99"]So are there only the rubber diaphragm ones available now? Mine have a wire spring base?[/quo you must have an early one ![]() |
Author: | womble99 [ Tue Nov 27, 2012 7:05 pm ] |
frednutz&co wrote: womble99 wrote: So are there only the rubber diaphragm ones available now? Mine have a wire spring base?[/quo you must have an early one ![]() Can't be that early, I am led to believe they are clubman seats? ie have the catch on the rear and the floor rail?? ![]() |
Author: | 69k1100 [ Tue Nov 27, 2012 8:14 pm ] |
Are they both the spring type? Surely someone could have repaired the seat with a sprung base at some stage. Not to mention it wasn't uncommon for them to use what was availiable during manufacturing. |
Author: | John Smidt [ Wed Nov 28, 2012 1:36 pm ] |
They did at one stage have the spring type base, but changed back to the rubber type after a short period of time, The spring type base can be obtained, However I would convert to the rubber type |
Author: | Dylans Clubby [ Fri Nov 30, 2012 3:57 pm ] |
womble99 wrote: frednutz&co wrote: womble99 wrote: So are there only the rubber diaphragm ones available now? Mine have a wire spring base?[/quo you must have an early one ![]() Can't be that early, I am led to believe they are clubman seats? ie have the catch on the rear and the floor rail?? ![]() Correct. From memory (not reliable...) I'm pretty sure they are rubber, not springs. I'll check them out, cheers all! |
