It is currently Thu Aug 14, 2025 11:39 am
 Post subject: Mark 1 Cooper S gearbox
PostPosted: Wed Nov 28, 2012 9:48 pm
What sort of money are you looking at to rebuild a Genuine Mark 1 Cooper S Gearbox/333?
PostPosted: Wed Nov 28, 2012 10:46 pm
Lots!
PostPosted: Wed Nov 28, 2012 11:44 pm
The Mini King
It All depends on what needs to be replaced, if all the gears ( with the Mk1 first gear on the cluster and the first & second sliding hub are often worn )
are ok then most people that do the job the correct way would put new bearings and diff thrust washers in, often you will need a new diff pin aswell
oops double post :oops:
The Mini King
PostPosted: Thu Nov 29, 2012 7:34 am
I heard the 22G1100 cluster gears for the Mk1 S and Sprite boxes are getting rarer, and dearer...
PostPosted: Thu Nov 29, 2012 4:01 pm
Speak to the guys at Mini Performance (02)4573 1206 I am sure they will be able to help you.
PostPosted: Thu Nov 29, 2012 4:24 pm
Thanks for the replies guys, I thought someone may have had a recent full gearbox rebuilt and might be able to put a close dollar figure, or a close ballpark figure.
+1 on this!
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Thu Nov 29, 2012 7:40 pm
$1500 to $2000 & upwards depending
PostPosted: Thu Nov 29, 2012 8:05 pm
Thanks once again Matt
Users browsing this forum: Bing [Bot] and 305 guests
