Mark 1 Cooper S gearbox https://www.ausmini.com/forums/viewtopic.php?f=2&t=79353 |
Author: | Gezo [ Wed Nov 28, 2012 9:48 pm ] |
Post subject: | Mark 1 Cooper S gearbox |
What sort of money are you looking at to rebuild a Genuine Mark 1 Cooper S Gearbox/333? |
Author: | brett [ Wed Nov 28, 2012 10:46 pm ] |
Lots! |
Author: | John Smidt [ Wed Nov 28, 2012 11:44 pm ] |
It All depends on what needs to be replaced, if all the gears ( with the Mk1 first gear on the cluster and the first & second sliding hub are often worn ) are ok then most people that do the job the correct way would put new bearings and diff thrust washers in, often you will need a new diff pin aswell oops double post ![]() |
It All depends on what needs to be replaced, if all the gears ( with the Mk1 first gear on the cluster and the first & second sliding hub are often worn ) are ok then most people that do the job the correct way would put new bearings and diff thrust washers in, often you will need a new diff pin aswell |
Author: | drmini in aust [ Thu Nov 29, 2012 7:34 am ] |
I heard the 22G1100 cluster gears for the Mk1 S and Sprite boxes are getting rarer, and dearer... |
Author: | AWOODY [ Thu Nov 29, 2012 4:01 pm ] |
Speak to the guys at Mini Performance (02)4573 1206 I am sure they will be able to help you. |
Author: | Gezo [ Thu Nov 29, 2012 4:24 pm ] |
Thanks for the replies guys, I thought someone may have had a recent full gearbox rebuilt and might be able to put a close dollar figure, or a close ballpark figure. |
Author: | danny_ [ Thu Nov 29, 2012 4:24 pm ] |
AWOODY wrote: Speak to the guys at Mini Performance (02)4573 1206 I am sure they will be able to help you.
+1 on this! |
Author: | TheMiniMan [ Thu Nov 29, 2012 7:40 pm ] |
$1500 to $2000 & upwards depending |
Author: | Gezo [ Thu Nov 29, 2012 8:05 pm ] |
Thanks once again Matt |
