more than a couple of things happen on idle to help your engine run high in temp
"If",,, (as you say you have ruled out head-gasket issues) then "IF" that`s true (& it`s a big "IF") so if there is no headgasket issues & all else is in perfect working order,,, then go to the "Firstly" paragraph
If not,,, & if you think there really are other issues like head-gasket &/or lean carby mixtures &/or retarded ignition timing &/or any combination of any/all of the above... then refer to repairing "head gasket & other overheating related issues" paragraph before proceeding any further
so...
"Firstly"--> the water pump is barely turning any water over at all on idle,,, so what i suggest is to rip the water pump out,,, physically go to your mini specialist,,, annoy the phark out of them to physically inspect each water-pump that they have in stock & buy the one with the biggest impeller but also the one that has it`s impeller fitted closest to the alloy pump housing.
there`s a gap on them all, but the one with the least gap is going to work far better that the one with the largest gap
2ndly--> the fan doesn`t actually do much fanning on idle either,,,, so again i`d make sure that the fan is actually fitted the right way round,,, & also that it`s fan blades actually line up with the lip on the fan shroud
if the fan is too far inside the rad shroud ,,, or not far enough in,,, then it won`t push as much air as it should
3rdly--> Simply because the BMC factory knew about the stationary idling heating-up issues inherent in their design, they actually made it known in their owners manual to turn the heater on in hot climate while idling stationary,,, sounds funny hey? but it`s true!!!... so it was known from the factory on day one that idling a mini will cause it`s engine temp to rise somewhat... however, this generally means it will climb to about 3/4 temp & stay there--> providing all else is in good order))), no leaky head-gaskets, no cracked heads & in perfect state of tune (IE: not lean or retarded)
So,,, what we do is--> make sure there are no headgasket issue 9Don`t just guess,,, diagnose it properly) we also make sure there are no running lean mixtures or air leaks or ignition timing retarded or any other tune related issues that can cause running hot problems... we also block-off (Modify the cooling system) & make the little water outlet (heater take-off at the back end of the head) & take a hose from there & make a fitting fit into the top tank of the radiator (probably cost about $10 at your local radiator shop) & put your new by-pass hose from the back of the head into that new fitting in the top tank of the radiator
this will do wonders to your cooling system in a number of depts
we also make sure of item 'firstly" & item "2ndly" too,,, the 3rdly one can be addressed by adding another heater matrix to the back end of the head (where the heater take-off usually is) however we find that not necessary on our engines,,, but many other people do use it.
& then 4thly-> you can add an electric thermo fan to the underside of the passengers side inner mudguard ,,, generally with the std inner-guard panel still in place makes for a fairly weak suction tho,,, so removal of that grille section of the inner guard & mounting your new thermo fan as close to the radiator as possible is going to be far more effective than just whacking it onto the outside of that grille yeah?
I like the thermo-fan idea however correct placement, quality insulated mountings, & a decent control unit are a must
there are many ways to stuff a kitten,,, try the best way first (it`s usually the simplest)
& people--> just so we are on the same page here,,,,generally speaking , a blocked (or semi-blocked) radiator will cause overheating while driving along at higher rpms (like high-way use) more-so than on idle,,, altho i`m not going to argue that it may ( & sometimes does) cause overheating on idle,,, but more than likely the owner would normally suggest an over-heating situation while motoring down the high-way
hope this helps,,,
& yes John i know, you`re right... i will keep doing this hey
