It is currently Mon Aug 04, 2025 7:48 am
PostPosted: Mon Dec 03, 2012 2:14 pm
Where is the flasher can located in a 92 rover mini
and the location of the relay that drives it
I have a small problem; the L&R indicators
are not working, and the hazard lights have also
gone on holidays.
the fuses are all ok, just need to find the flasher can & relay
Les
PostPosted: Mon Dec 03, 2012 2:21 pm
This applies to a 97 model, but they're pretty close.
http://www.ausmini.com/forums/viewtopic.php?t=52720&postdays=0&postorder=asc&highlight=flasher&start=13
 Post subject: flasher can
PostPosted: Mon Dec 03, 2012 2:46 pm
Thanks for the Info,
looks like a few hours in the shed again
Les
PostPosted: Mon Dec 03, 2012 6:30 pm
It'll likely be the hazard switch.
PostPosted: Mon Dec 03, 2012 6:40 pm
Harley wrote:
Same place in my 93 rover.
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Tue Dec 04, 2012 8:50 am
I have replaced the flasher canit, system still not working
fuses in the fuse block are ok
is one of the line fuses in the engine compartment
connected to this system ???
Brains trust, answers please
Les
PostPosted: Tue Dec 04, 2012 9:17 am
One of the fuses in the engine compartment ends up at the indicators, but I think its shared with other functions so if the indicators are the only thing not working consider other possibilities.
Do your hazzards work?
If so it could be the column switches. I've had that before in a rover.
 Post subject: flashers
PostPosted: Tue Dec 04, 2012 10:39 am
Thanks, for all the Info.
Yes it was a 10 amp line fuse under the bonnet
thanks to all the Mini brains trust
Les
Users browsing this forum: Barkfast and 119 guests
