It is currently Mon Aug 04, 2025 10:45 am
PostPosted: Tue Nov 27, 2012 3:22 pm
hi there a friend of mine has a mini matic, its 1968, and it has no rear seatbelts the rwc guy said to pass a rwc it would have to get an engineer cert for rear seatbelts, i thought that rear seatbelts were std
the answer i would like to know did they come std on 1968 minis because of ADR or has my friend just forgotten to put them in.
thanks
PostPosted: Tue Nov 27, 2012 3:28 pm
68 minis didn't have them.
If he takes them out the guy can't reject him.
As a side note, how would the mechanic know if they're engineered or not?
Do they put mod codes on the rego label or something?
PostPosted: Tue Nov 27, 2012 3:31 pm
thanks harley.
PostPosted: Tue Nov 27, 2012 3:53 pm
No rear belts in a 1968, they were not compulsory fitment until Jan 1972 or 73.
So not needed for rego... my 1970 `Matic hasn't got em either.
PostPosted: Tue Nov 27, 2012 5:05 pm
correct they are not required to be fitted due to the regs at the time of production, however.... if rear seat belts ARE installed they must be engineer certified.
PostPosted: Tue Nov 27, 2012 5:30 pm
my 68 matic had an after market year seat belt fitted so we could put the baby cradle in there
it didn't have one before that
PostPosted: Tue Nov 27, 2012 5:33 pm
As silly as it sounds if they were installed as an accessory in 1968 they didn't need engineering and also it is illegal to remove belts once they are fitted. :shock:
PostPosted: Wed Nov 28, 2012 7:35 am
My 1963 mini had rear seatbelts installed by a previous owner, but were not engineered. If I take them out would I be picked up at rego time if the inspector saw the old mounting holes?
PostPosted: Wed Nov 28, 2012 12:01 pm
Why not leave em in?
If frayed or damaged, you can legally replace them..
PostPosted: Sun Dec 02, 2012 1:06 pm
If I leave them in I was told by rego inspector that they have to be engineered as 1963 Mini's never had rear belts fitted originally.
1963 Morris 850
PostPosted: Sun Dec 02, 2012 1:11 pm
That sounds right. The inspector cannot inspect them as safe because they have not been engineered. Just pull them out, to keep them happy
PostPosted: Mon Dec 03, 2012 1:05 pm
And when I pull them out should I leave the seatbelt mounting bolts in or try to cover up the holes left?
1963 Morris 850
PostPosted: Mon Dec 03, 2012 2:34 pm
I think you need a new rego inspector... :wink:
But if he's forcing you to remove them, he then really can't bitch if you leave the mounting points empty.
Users browsing this forum: No registered users and 127 guests
