It is currently Thu Jul 31, 2025 5:58 am
PostPosted: Wed Dec 05, 2012 12:36 pm
Hi guys, just a quick one, can anybody with a 13x7 wheel like a superlite, ultralite, etc please measure the inside diameter of the rim at the hub, and tell me what the wheel is, and offset if known?
Thats all I need. Thanks.
:D
PostPosted: Wed Dec 05, 2012 9:07 pm
You can measure mine on Sunday at Bundoora :wink:
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Wed Dec 05, 2012 9:26 pm
That might work! Thanks! :D
PostPosted: Thu Dec 06, 2012 12:14 pm
heres lots of measurements i just took from a set that i will be selling soon
13 x7 et -7 deep dish
from the back of the hub( sits on the rotor or drum) to the rim edge inside 85 mm
front of hub ( wheel nut location ) to edge of rim outside 90 mm
inside dia of the rim 283 mm then steps out to 317 mm
40 mm at 283 to the step out
anything else?
yes selling 2 only brand new 13 x 7
i ran narrow rear drums and cooper disc front, so i used 7 inch back and 6 inch fronts
PostPosted: Thu Dec 06, 2012 12:35 pm
Dodge you're a legend! That's everything I could want to know.
Very much appreciated! Thanks.
:D
