It is currently Mon Jul 21, 2025 3:19 am
PostPosted: Sun Dec 09, 2012 3:07 pm
Hi. heading home from the Grand Day Out my left side wheel bearings failed. Had to drive to my cousins another 30k's.
Is there anyone localish that can help out? I need to still travel 350k's to get home. Spot of bother I say. Where can I get disk break bearings? Are they pressed in or can I knock them out?
Damian
You can call me on 0429982079
Image Image
PostPosted: Sun Dec 09, 2012 3:21 pm
The bearings aren't easy to get out of the car in an emergency situation.
Hub nut alone is the first obstacle - usually need a pretty big breaker bar.
If you did change it, you'd leave the outer race in the hub and just change the centres, it'll get you home.
PostPosted: Sun Dec 09, 2012 3:31 pm
thanks. think i'm good. hub nut was nearly off. split pin gone AWOL. bearings look good. needed to get message out quick incase things were bad. i'll let you know.
Image Image
PostPosted: Sun Dec 09, 2012 3:35 pm
Torque it up, get a pin in there, check it and your wheel nuts every 50km till home.
PostPosted: Sun Dec 09, 2012 3:36 pm
Fencing wire or a decent nail will do for a split pin... probably stronger than chinese split pins anyway.
PostPosted: Sun Dec 09, 2012 4:16 pm
thanks to all. on my way now.
Image Image
PostPosted: Sun Dec 09, 2012 8:55 pm
Rover Cooper
great to meet you today, what an effort to make it, safe trip back home, mate
PostPosted: Sun Dec 09, 2012 9:59 pm
good luck mate
First you get the money,then you get the power,then you get the Mini.
PostPosted: Sun Dec 09, 2012 10:22 pm
Home now. All is good.
No damage done apart from a very scuffed up disk and a chipped pad that needs replacing.
At least the bearings got a re-grease.
Good to see a few familiar face's in the crowd, even though I'd forgotten most of your names, and great to put faces to the names I see on here (Davo :wink: )
Thanks again to the people that offered help and to the people that phoned.
Image Image
