Calling for help. Stuck in Caroline Springs!!
https://www.ausmini.com/forums/viewtopic.php?f=2&t=79475
Author:  blueminivan [ Sun Dec 09, 2012 3:07 pm ]
Post subject:  Calling for help. Stuck in Caroline Springs!!
Hi. heading home from the Grand Day Out my left side wheel bearings failed. Had to drive to my cousins another 30k's.
Is there anyone localish that can help out? I need to still travel 350k's to get home. Spot of bother I say. Where can I get disk break bearings? Are they pressed in or can I knock them out?
Damian
You can call me on 0429982079
Author:  Harley [ Sun Dec 09, 2012 3:21 pm ]
The bearings aren't easy to get out of the car in an emergency situation.
Hub nut alone is the first obstacle - usually need a pretty big breaker bar.
If you did change it, you'd leave the outer race in the hub and just change the centres, it'll get you home.
Author:  blueminivan [ Sun Dec 09, 2012 3:31 pm ]
thanks. think i'm good. hub nut was nearly off. split pin gone AWOL. bearings look good. needed to get message out quick incase things were bad. i'll let you know.
Author:  Harley [ Sun Dec 09, 2012 3:35 pm ]
Torque it up, get a pin in there, check it and your wheel nuts every 50km till home.
Author:  drmini in aust [ Sun Dec 09, 2012 3:36 pm ]
Fencing wire or a decent nail will do for a split pin... probably stronger than chinese split pins anyway.
Author:  blueminivan [ Sun Dec 09, 2012 4:16 pm ]
thanks to all. on my way now.
Author:  Davo111 [ Sun Dec 09, 2012 8:55 pm ]
great to meet you today, what an effort to make it, safe trip back home, mate
Author:  minimy [ Sun Dec 09, 2012 9:59 pm ]
good luck mate
Author:  blueminivan [ Sun Dec 09, 2012 10:22 pm ]
Home now. All is good.
No damage done apart from a very scuffed up disk and a chipped pad that needs replacing.
At least the bearings got a re-grease.
Good to see a few familiar face's in the crowd, even though I'd forgotten most of your names, and great to put faces to the names I see on here (Davo :wink: )
Thanks again to the people that offered help and to the people that phoned.
