It is currently Sat Jul 19, 2025 1:10 pm
PostPosted: Sat Dec 15, 2012 11:11 am
Just wondering if anyone has any ideas or have used something to replace the long oil separator crank case breather on the clutch housing. Cheer, Tom.
If its yours, customize it !
PostPosted: Sat Dec 15, 2012 11:34 am
How about this
http://www.dsnclassics.co.uk/acatalog/info_1081.html
Cost me 19 pounds delivered to my door
1963 Morris 850
PostPosted: Sat Dec 15, 2012 11:57 am
That could work
PostPosted: Sat Dec 15, 2012 6:18 pm
Flywheel housing breather is useless on long LH bends at high rpm, the primary gear tosses heaps of oil up it.
It is not really an oil separator, the mesh is in there more as a flame trap.
I closed my 1360 one off with a steering rack plate, then ran a 12mm nylon line up to the rocker cover. This equalizes crankcase pressure top to bottom.
My breather runs from the rocker cover to a Toyota PCV valve and then into the intake manifold.
Note this is an old pic, the flywheel housing breather shown on there was capped off.
