It is currently Sat Jul 19, 2025 10:26 am
PostPosted: Wed Dec 12, 2012 7:40 pm
Anyone know which head gasket I can use for this?
I need to run 2 of them to allow valve clearance. The 1275 gasket I have doesn't line up correctly with the far water jacket ports, everything else seems fine just two water jacket ports.
I have been thinking of getting some copper and water cutting one the thickness I want to?
Any experience here appreciated :?
Mini's I grew up with
Slot car couch
PostPosted: Wed Dec 12, 2012 8:07 pm
A 1275 gasket lines up OK if you use a 1275 head, as you say it won't work on a smallbore head.
If I were you I'd try 2x ACL Monotorque gaskets first, they have a pretty good fire ring and might work OK. Back in the 60s when we used to bore 1098s to 66.5mm, a smallbore gasket worked OK.
PostPosted: Wed Dec 12, 2012 8:19 pm
Thanks Kevin,
It seemed that two of the water ports in the block didn't line up properly with the 1275 head gasket? I only quickly had a look tonight but I will look again and maybe take a photo to explain what I am looking at.
Slot car couch
PostPosted: Wed Dec 12, 2012 8:26 pm
what head are you using
PostPosted: Wed Dec 12, 2012 9:13 pm
1100s 12G940 with cooper S exhaust valves.
Slot car couch
PostPosted: Wed Dec 12, 2012 9:32 pm
1275 gasket should work fine then, as not all the water holes at the ends in the smallbore block are used with the 1275 head. :wink:
Just check how the gasket sits over the row of small holes along the front of the block. Sometimes they need plugging and redrilling smaller.
PostPosted: Fri Dec 14, 2012 4:22 pm
This is how it looks placed on block. All the front holes appear to line up ok.
Slot car couch
PostPosted: Fri Dec 14, 2012 4:50 pm
Put the 2 studs in that locate the gasket (there's 2 holes are smaller) and have another look.
If you are then still worried about that water hole in the block, take a round file to chamfer it, or touch it with a die grinder.
