It is currently Sun Jul 20, 2025 7:55 am
 Post subject: Hardy Spicer outputs
PostPosted: Sat Dec 15, 2012 5:54 pm
As mentioned elsewhere I scored an Auto engine today for the 295 head and hardy spicer outputs. I took the diff off holus-bolus and left the engine for another bloke.
My question is, are the outputs from the diff hardy spicer specific?
And the single side cover I retrieved from the auto diff cover (they only have one side cover, the other is integral to the casing) looks different to the Cooper S type, is my memory correct?
PostPosted: Sat Dec 15, 2012 6:05 pm
Yes the output shafts are Hardy Spicer U/J specific, and auto sidecovers are different to a Mini.
Although S shafts are slightly different length & material? to 850-Mini K ones the inboard spline is the same and the H/S joints fit.
PostPosted: Sat Dec 15, 2012 6:32 pm
Ok, thanks doc.
So the output shafts can be used on a manual box as well?
PostPosted: Sat Dec 15, 2012 6:56 pm
Mick wrote:
Ok, thanks doc.
So the auto output shafts can be used on a manual box as well?
I've not measured them but I believe they are same as S ones?
Note- re my previous post discussing splines, note I was talking about driveshafts, not the diff outputs..
PostPosted: Sat Dec 15, 2012 7:04 pm
Mick wrote:
Ok, thanks doc.
Yes, thanks Doc I understood your intent.
I haven't another to measure against here, but there seems to be a spacer on both sides of the diff, so I can't be sure if they're the same.
PostPosted: Sat Dec 15, 2012 7:09 pm
The Mini King
You Can Use the auto out put shafts on a Cooper S without Problems
However Check for wear on the gear part Autos are often worn more than Manuals in this area
PostPosted: Sat Dec 15, 2012 7:12 pm
Excellent, thanks Doc and John.
Users browsing this forum: No registered users and 65 guests
