Irish Yobbo wrote:
That other pipe that comes out from the bowl is an emissions thing, I think it goes to the charcoal canister. Wherever it goes, there shouldn't be any fuel coming out.
Your problem will be the float valve. Once it fills, the valve should shut off the floe well before it reaches the top of the float bowl. Since it's overflowing it looks like that's the problem.
What pressure are you running the fuel pump at?
There is no other pipe coming out of the float bowl. It's a small pin hole directly underneath the inlet. You can't see it if there is a fuel hose on there.
I suspected the float, but didn't have time to check before work. I'll have to grab another from the parts bin and see how I go.
Not sure about what PSI, the pump came straight off my moke and went straight onto the morris. Worked fine on both 1-1/4 and 1-3/4 setups.
Thanks for your help.
And Doc, do you think it's something other than the float? Not sure why it would suddenly have a hole in it, everything worked fine before it came off the car.
