Heat shield from early cooper id please https://www.ausmini.com/forums/viewtopic.php?f=2&t=79616 |
Author: | phillb [ Fri Dec 21, 2012 9:33 am ] |
Post subject: | Heat shield from early cooper id please |
Can someone please confirm that this is a cooper heatsheild as it has a bracket that I think is for the vac advance tube. See pic below If you are interested in it please PM me. I would be interested in just a standard cooper s heatsheild to buy or swap. The carbs and everything else with it appesrs to be cooper s. Thanks ![]() |
Author: | drmini in aust [ Fri Dec 21, 2012 9:40 am ] |
Yes I believe that is a Cooper one. ![]() |
Author: | Morris 1100 [ Fri Dec 21, 2012 10:13 am ] |
Yes, I agree, it is a Cooper one. I have one on my Morris 1100 at the moment. |
Author: | sitnlo62 [ Fri Dec 21, 2012 3:25 pm ] |
That Heat shield was used right through the range Including Cooper S which did not use the Vacuum advance. Just to be clear, Cooper S heat shields Did have that Bracket. In fact, so did the Clubman GT which can be clearly seen in the GT enginre bay pic on page 64 of vthe Book Spotlight On Mini Minor Down Under. Caption mistakedly says it is a Cooper s Engine Bay!! Dave |
Author: | drmini in aust [ Fri Dec 21, 2012 4:07 pm ] |
O/T but related- Note the Police Pack HS4 carbs on the Cooper S and Clubby GT did not use this shape heat shield, they had a 1 piece one. |
Author: | phillb [ Fri Dec 21, 2012 4:30 pm ] |
sitnlo62 wrote: That Heat shield was used right through the range Including Cooper S which did not use the Vacuum advance.
Just to be clear, Cooper S heat shields Did have that Bracket. In fact, so did the Clubman GT which can be clearly seen in the GT enginre bay pic on page 64 of vthe Book Spotlight On Mini Minor Down Under. Caption mistakedly says it is a Cooper s Engine Bay!! Dave Ok well if thats true it kinda makes sense, absolutely everthing else that came with that setup was correct so it seemed odd to end up with a different shield. I guess over the years many have just been replaced with sets without the bracket. |
Author: | sitnlo62 [ Fri Dec 21, 2012 6:12 pm ] |
drmini in aust wrote: O/T but related-
Note the Police Pack HS4 carbs on the Cooper S and Clubby GT did not use this shape heat shield, they had a 1 piece one. Correct, in fact it was an AH Sprite, MG Midget heat shield converted to suit 1 1/2 SU's on a mini... Dave |
Author: | phillb [ Fri Dec 21, 2012 9:15 pm ] |
sitnlo62 wrote: drmini in aust wrote: O/T but related- Note the Police Pack HS4 carbs on the Cooper S and Clubby GT did not use this shape heat shield, they had a 1 piece one. Correct, in fact it was an AH Sprite, MG Midget heat shield converted to suit 1 1/2 SU's on a mini... Dave What is actually the purpose of the bulbous section of the metal vac line when one is fitted to that bracket. Is it just shaped that way so the bracket can support it? |
Author: | drmini in aust [ Fri Dec 21, 2012 9:26 pm ] |
Nope, it's a fuel trap, to protect the diaphragm in the vac advance.. |
Author: | phillb [ Fri Dec 21, 2012 9:31 pm ] |
drmini in aust wrote: Nope, it's a fuel trap, to protect the diaphragm in the vac advance..
Ah OK. Yeah it seemed a lot of fuss just to support a bit of tube. Thanks for all the replys and help everyone. |
