Lightening doors https://www.ausmini.com/forums/viewtopic.php?f=2&t=79650 |
Page 1 of 3 |
Author: | 1380 K [ Mon Dec 24, 2012 7:15 pm ] |
Post subject: | Lightening doors |
I'm building a fast road car with weight a major factor. Just looking for ideas on getting the weight down in aus wind up doors. Seen some of the uk guys cut out metal from the inside of door under the door card. Not sure How this would go in a crash. Has anyone drilled out part of the winding mechanism?m |
Author: | Harley [ Mon Dec 24, 2012 7:25 pm ] |
Weight saving on aussie doors is easy in some respects, and difficult in others. Firstly, getting rid of the door bins is the easiest and biggest chunk of weight. Plastic window winder and door pull handles are lighter than alloy ones, do your door cards in carbon or polystyrene sheet, and for the adventerous - replace the quarter window assembly with a polycarbonate one that doesn't open. If you want the windows to wind up and down, don't touch the mechanism - thats just asking for trouble. |
Author: | Kennomini [ Mon Dec 24, 2012 7:36 pm ] |
The MKI sliding window doors are the lightest. Do you have Leyland doors or Deluxe/mini K wind up doors? Cutting the inner frame out of the door will weaken it in a crash and may be illegal (I'd guess more chance of it being illegal if the car is a Leyland mini due to the ADR's). If you just drill holes in the winding mechanism I don't see any problem with that, you can also remove the door pockets to save weight and replace the glass with perspex/"lexan glass". |
Author: | Lillee [ Mon Dec 24, 2012 7:47 pm ] |
For a road car? I gave up on that years ago. I'm in the "If you want to go faster, you need more power" frame of mind. Didn't particularly want to go cutting and drilling Lillee up... So I dynamatted my whole interior including doorcards and bonnet. Don't regret it. Now just need to work on that power bit... Sorry back to doors |
Author: | drmini in aust [ Mon Dec 24, 2012 7:51 pm ] |
I have a GT RH door here that a PO cut and bent the crap out of the inner panel so he could get the *&^$(@ window mechanism out. Obviously he didn't know what he was doing.. ![]() Anyway now I'm going to use it in the van, maybe I'll weld all the hacked stuff back up but more likely it'll get a partial bentinnerpanelectomy. ![]() |
Author: | 1380 K [ Mon Dec 24, 2012 8:27 pm ] |
Thanks for the ideas. I have morris k/deluxe doors, not a fan of slide window doors. I'm loving the idea of using lexan in the quarter window and making it fixed. I can't open it anyway due to my mirrors and the rubber is shot and leaking anyway. Might cut the door bins off and see how the weight is then. lexan might scratch too much over the years being wound up and down so i might keep glass in it. And Lillee I intend on working the motor for as much power as well ![]() |
Author: | Kennomini [ Mon Dec 24, 2012 8:47 pm ] |
If your careful you can remove the pockets without destroying them so you can resell them or save them for replacement panels. |
Author: | 1380 K [ Mon Dec 24, 2012 8:58 pm ] |
Are they spot welded? My guess is yes being bmc |
Author: | braad [ Mon Dec 24, 2012 9:04 pm ] |
turbo it/more boost to negate any weight differences! |
Author: | Lillee [ Mon Dec 24, 2012 9:07 pm ] |
braad wrote: turbo it/more boost to negate any weight differences!
+1 ![]() |
Author: | TheMiniMan [ Mon Dec 24, 2012 9:07 pm ] |
perspex sliders in alloy panel-d clubby doors ![]() ![]() they weigh less than the air around them ![]() |
Author: | 1380 K [ Mon Dec 24, 2012 9:10 pm ] |
I'd love to but I've get enough problems from my n/a a series motor let alone adding more things to go wrong and put the whole motor under more strain haha. |
Author: | braad [ Mon Dec 24, 2012 9:12 pm ] |
TheMiniMan wrote: perspex sliders in alloy panel-d clubby doors
![]() ![]() they weigh less than the air around them ![]() are you saying the outer door skin is alloy?? or just the door trim/internal |
Author: | braad [ Mon Dec 24, 2012 9:15 pm ] |
1380 K wrote: I'd love to but I've get enough problems from my n/a a series motor let alone adding more things to go wrong and put the whole motor under more strain haha.
I just saw a thread on turbocharged 998s getting useable 120bhp. So i'd reckon that could solve your problem! |
Author: | 1380 K [ Mon Dec 24, 2012 9:48 pm ] |
My 1380 with some more tweaks and a light car should do me well. For a bit |
Page 1 of 3 | All times are UTC + 10 hours |
