It is currently Wed Jul 09, 2025 5:12 pm
PostPosted: Sat Dec 22, 2012 11:14 pm
Hi Guys, need to shrink a rubber door seal.. Its a 2 piece seal and the new one is thick and I can not shut the door.. Any ideas?
Heat gun?
Cheers Brett
PostPosted: Sun Dec 23, 2012 7:05 am
Hi Brett,
Have you some information or a link to the seal you are using?
I have not seen a new two piece seal for years.
PostPosted: Sun Dec 23, 2012 7:46 am
Look at your door seal material and that's it. Going to hit it with a heat Jun worse case I stuff it, eitherway its unusablevlike it is.
PostPosted: Sun Dec 23, 2012 8:40 am
They're like this for the first little while, but they will come good.
I managed to pick up a set of two piece seals (silver pinch strip) a little while back as well. It doesn't get the abuse the original car would have, so they will last a long time yet.
PostPosted: Sun Dec 23, 2012 10:41 pm
The door will not even shut. way to big. Mick can you put a pic up of yours?\Thanks Brett
