Engine reassembly Q's (Metro lump) https://www.ausmini.com/forums/viewtopic.php?f=2&t=79687 |
Page 1 of 2 |
Author: | Angusdog [ Fri Dec 28, 2012 11:48 am ] |
Post subject: | Engine reassembly Q's (Metro lump) |
Hi, I'm readying the Metro lump to go in our Clubman Estate and have a few questions: 1. This ring is not referred to in the Haynes manual. Does it go against the main oil seal, between it and the flywheel? ![]() 2. Can I use Loktite instead of the locking tabs for the flywheel housing bolts which go under the flywheel? Or make my own locking tabs from 1mm steel? Or do I need genuine items (which at this time of year will delay getting it running)? 3. I'm putting in a slightly lightened Mini flywheel instead of the verto clutch, which means the corresponding starter motor - any things to watch for? I will undoubtedly have more questions as I go along, so thanks in advance for any assistance. One thing I want to do is build a stand so I can get it running and test it before fitting it to the car, since it's 1100 lump is still fine and in the car. Cheers, Simon aka Angusdog. |
Author: | drmini in aust [ Fri Dec 28, 2012 11:53 am ] |
1. It goes against the oil seal, effectively it's an oil slinger. 2. Loctite 262 works fine. Use spring washers too if you want. 3. It's a bolt-in job, you need to use all the pre-Verto mechanism naturally. |
Author: | Angusdog [ Fri Dec 28, 2012 12:45 pm ] |
Cheers Doc! I'll crack on until I get to the next hurdle. |
Author: | Angusdog [ Fri Dec 28, 2012 3:16 pm ] |
Should I use more or less RTV than the previous owner for the thermostat housing? ![]() ![]() Unsurprisingly, there wasn't a thermostat in there. Seriously though, can/should I drill through this for the heater valve? ![]() |
Author: | drmini in aust [ Fri Dec 28, 2012 3:17 pm ] |
Yep just drill a 1/2" hole there. ROFL @ the thermo housing... ![]() |
Author: | mini_mad_matt [ Fri Dec 28, 2012 4:49 pm ] |
You don't really need to have a stand to test run the engine. You can just hook everything up as it would be in the car and start it up on the ground. It won't fall over but it may want to wander away if you don't put your foot on it. Then when you are ready just drop it into the car pretty much complete. |
Author: | GT mowog [ Fri Dec 28, 2012 5:40 pm ] |
Hey Angus, just be aware that those heads take a slightly odd-ball thermostat. The machined register for it is slightly smaller than the usual one. You can trim a stock one down to fit though. |
Author: | michaelb [ Fri Dec 28, 2012 5:49 pm ] |
Re starting on the ground I sat mine on an old blanket and connected the exhaust system which acted as a stabiliser to stop the engine falling over, even though I doubt it would fall. Just keep the blanket away from the exhaust ![]() ![]() ![]() ![]() |
Author: | Angusdog [ Sun Dec 30, 2012 12:42 pm ] |
Thanks for the replies so far. I've lapped in the valves today; quite a satisfying job. The head gasket is copper on one side and silver on the other. Which way up? |
Author: | drmini in aust [ Sun Dec 30, 2012 12:52 pm ] |
Copper ^^^ |
Author: | Angusdog [ Sun Dec 30, 2012 1:04 pm ] |
Thanks Doc - this is like a 24/7 helpline! |
Author: | drmini in aust [ Sun Dec 30, 2012 1:05 pm ] |
Angusdog wrote: Thanks Doc - this is like a 24/7 helpline!
"Dear Dorothy Dix".... (the oldies here would remember) ![]() |
Author: | peterb [ Mon Dec 31, 2012 7:16 am ] |
And don't forget the 6 tubes of slazzo for the thermostat housing, rocker cover and manifold. ![]() |
Author: | Angusdog [ Thu Jan 03, 2013 7:56 am ] |
Right, three hopefully quick questions: 1. I have two flywheels. The one on the left is lightened (6.2kg) and the one on the right isn't (7.3kg) but the starter ring needs to be swapped. I tried heating it but my MAPP burner either didn't go hot enough or more likely I had little idea about what I was doing. Is this feasible? I will get a clutch workshop to swap if it is. ![]() 2. The sandwich plate under the metro thermostat housing points straight at the radiator. I could drill the holes in it larger and move it 120 degrees to the rear. I believe it should go to the bottom radiator hose. The metro lump doesn't run a bypass hose in the head. Or what's the best option? ![]() 3. Is is okay to fit a multi connector for the engine wiring? Not the starter motor obviously, but I need to connect the basic engine wiring to the car and that seems like the best option. Or should I solder them and fit heat shrink tubing over the joins. Thanks for the advice so far - quite reassuring having this knowledge on tap. |
Author: | drmini in aust [ Thu Jan 03, 2013 10:13 am ] |
Q1. You will NOT get the ring gear off with heat. It's a shrink fit and very tight. Spend A$50 and buy a new one. What's wrong with the one that's on there, if worn you keep it & fit a Gemini starter instead (these mesh in from the front not the back) |
