It is currently Sat Jul 26, 2025 12:23 am
 Post subject: Clubman Wheel Arches
PostPosted: Thu Jan 03, 2013 8:09 am
Would anyone here who has fitted arches, specifically Group 2 or similar to a clubman, know that if there are some available that bolt straight onto the original screw locations?
Do UK clubmans have different mounting holes hence importing a set would require new holes to be drilled, but a locally picked up set might not?
Cheers!
PostPosted: Thu Jan 03, 2013 9:39 am
From memory the arches sit a little higher than the screw on innocenti type flairs so the holes are covered by the flair.
