It is currently Mon Jul 28, 2025 3:04 am
 Post subject: alternator ID
PostPosted: Wed Jan 02, 2013 2:38 pm
How do I tell the difference between my collection of alternators, what's a 70 amp and whats a 75 or (80amps if they exist).
PostPosted: Wed Jan 02, 2013 2:40 pm
Post the model numbers on here and we'll have a squiz.
PostPosted: Wed Jan 02, 2013 4:53 pm
...& if you're talking about stock Lucas alts, then none of them come close to 70A :lol:
cheers,
Jacob
PostPosted: Wed Jan 02, 2013 5:26 pm
Most of them are identical and have 15C on the back of them. A couple look similar but have a plastic back cover making them a longer item.
Where should the model number be?
PostPosted: Wed Jan 02, 2013 6:17 pm
Most common original Lucas ones sold here-
1/2 plastic back cover = 15AC (separate regulator, Mini K and Mk2S) 28A approx,
and
full plastic back cover = 16ACR (built in regulator, Clubbies) 34A approx.
There is also a 15ACR? in between these two, it has no plastic back cover and the slip ring and diode setup inside is different. Not sure of output but probably between the 2 above.
Most `Lucas' hi-po ones available now are not Lucas, but aftermarket.
PostPosted: Wed Jan 02, 2013 7:37 pm
When does the 28a become a little too small? How much has to be running?
PostPosted: Wed Jan 02, 2013 7:49 pm
The 28A one is fine, day or night, even with H4 headlights and a couple of driving or fog lamps.
Remember the Mk1 cars, even the Cooper S only had a 22A generator, and that was fine back in the 60s.
You really don't need a BIG alternator unless you are into doof-doof stereo systems.
 Post subject: 70 Amp Alternators.
PostPosted: Thu Jan 03, 2013 7:19 am
I sell 70 Amp Brand New Alternators. They bolt straight on. Always good to have some strong back up of power source in a Mini.
"Let us remove your "SHORTS"
PostPosted: Thu Jan 03, 2013 10:15 am
Are they as small and light as the old mini ones?
 Post subject: Alt
PostPosted: Thu Jan 03, 2013 2:57 pm
Bigger alternator more weight.
