It is currently Sat Aug 02, 2025 7:31 pm
PostPosted: Sat Jan 05, 2013 7:43 pm
I have a 1275 Morris 1100S engine that has major low oil psi issues, the engine is still together but I believe it is the main bearings that are causing the problem.
What I want to get an idea of rebuild and machining costs on a few things, the bare minimum first and then the more extensive machining that may be needed.
So lets say it's just the main caps, what would that cost to replace :?:
Or on the other hand lets say the whole crank assembly is damaged, what would I be looking at :?: and rough costs please.
-main bearings
-Line boring
-crank grind
-oil pump
Am I over looking some things or should I ignore some things that rarely need doing in this situation?
Also seeing as it is an 1100S that means it's most likely a large journal crank so what would it cost to wedge, balance and stroke it?
PostPosted: Sat Jan 05, 2013 7:58 pm
-main bearings
-Line boring
-crank grind
-oil pump
Main caps are not interchangeable. If the main bearings have not spun, new bearings will fix it. Otherwise an engine reco shop will close the caps by grinding a little off, then line bore it. It would cost more than another block & caps would.
Crank grind- last one I got done last year cost $200 for a straight regrind.
If you want it stroked, it's $300.
Oil pump is under $50.
Crank wedging-I did my own (took 6 hrs)- GR does it in about 1/2 that as his mill is bigger. Allow $400, it may be less.
Balancing- $less than $100 including flywheel assembly.
As for whether it's a big journal crank, the changeover point was at engine number 12YD/Ta/H10488. Below that it's a small journal tufftrided crank with S rods. Can't stroke them but they work just fine and don't really need wedging for a street motor.
Crank test the crank before proceeding, regardless which one it is.
