DCOE 40 Float Level https://www.ausmini.com/forums/viewtopic.php?f=2&t=79823 |
Author: | sam_1100 [ Sat Jan 05, 2013 12:23 pm ] |
Post subject: | DCOE 40 Float Level |
I think I've found the float level settings for every other car except a mini! Does anyone have any info or links? Car goes sweet up to 4000 rpm and then seems to get starved of fuel... and so far I've just used a generic setting from "How to Powertune Webers", so want something a bit more accurate to hopefully solve this. PS Its a spiced up little 1098 Thankssss! |
Author: | drmini in aust [ Sat Jan 05, 2013 12:52 pm ] |
The number in that Weber book for a DCOE is correct, so is the one it gives for the Dellorto DHLA. |
Author: | sam_1100 [ Sat Jan 05, 2013 12:55 pm ] |
You mean the one with the "how to set the float level" area, not a specific car at the back of the book? Was 12mm closed (standard) and 26mm open. Was far longer stroke than I had set up originally when it ran well is all. (I don't know what I ran before, I can't find the info!) |
Author: | drmini in aust [ Sat Jan 05, 2013 1:13 pm ] |
p49.. read it. It is 7.5mm (gasket vertical) and 15mm droop (gasket horizontal) for a Weber DCOE. |
Author: | sam_1100 [ Sat Jan 05, 2013 2:05 pm ] |
Yep got that but 12-26mm for the plastic floats next page. I've seen various listings for different engines having different float levels is all |
Author: | drmini in aust [ Sat Jan 05, 2013 2:22 pm ] |
does it have a plastic float? most Webers here have brass ones. My Dellorto has plastic though. |
Author: | sam_1100 [ Sat Jan 05, 2013 2:36 pm ] |
Yep plastic-new model ![]() Cheers |
