opinions please.... should i replace the rear radius pins? https://www.ausmini.com/forums/viewtopic.php?f=2&t=79843 |
Author: | Blunder [ Sun Jan 06, 2013 11:51 pm ] |
Post subject: | opinions please.... should i replace the rear radius pins? |
Here is a snap... No expert but I think this is cream crackered! Lol Just checking I am correct and not that this is usual on the bush side and not to worry.... ![]() ![]() |
Author: | kirby [ Mon Jan 07, 2013 12:48 am ] |
That will polish out* ![]() *unless its a new aftermarket one that they forgot to harden. |
Author: | Blunder [ Mon Jan 07, 2013 12:54 am ] |
Looks original 1965! |
Author: | Convertible Mini [ Mon Jan 07, 2013 6:48 am ] |
Post subject: | Worn. |
With that much wear I am sure it will give you unwanted rear wheel steer. |
Author: | drmini in aust [ Mon Jan 07, 2013 7:53 am ] |
Check the hardness of the new ones, if you can file the corner of the straight part it's soft = NFG. Has to be hard (61HRC or better) or the rollers will chew it up. |
Author: | Blunder [ Mon Jan 07, 2013 10:58 am ] |
It was wobble and play free..... But I will get some new ones.... |
