It is currently Tue Jul 29, 2025 3:52 pm
 Post subject: 997 valve springs.
PostPosted: Thu Jan 10, 2013 9:48 pm
Greetings all.
Re-assembling a Cooper 997 head after getting it machined. Measured the spring (s) length, and they are all around 4". The book says they should be 4 & 1/2". Would this effect the performance much?
Alex.
PostPosted: Thu Jan 10, 2013 10:01 pm
Assuming you mean they're 4" uncompressed, and not installed in the head, they're either shorter springs than standard, or they've lost 1/2" of springiness. If they've lost springiness, then valve bounce will set in a lot earlier than if they were new
I'd ditch them for newies - good springs are cheap
PostPosted: Thu Jan 10, 2013 10:08 pm
Thanks Simon.
Sounds like a fresh set will make sure all's good.
Alex.
Users browsing this forum: No registered users and 114 guests
