It is currently Mon Jul 21, 2025 10:17 am
 Post subject: Aftermarket Gauges
PostPosted: Fri Jan 11, 2013 12:02 pm
Die Die Die!!
Hi, has anyone fitted after market gauges to their car ?
im looking into the possibility of some for my Moke, i was looking into GPS Gauges - http://www.speedhut.com/customizer.i?clid=215638
id love to see some pics if anyone has aftermarket gauges
Nick
PostPosted: Fri Jan 11, 2013 5:11 pm
I have autometer gauges in my oval dash instead of the smiths
PostPosted: Fri Jan 11, 2013 8:33 pm
Die Die Die!!
nice, were they easy to hook up ?
PostPosted: Fri Jan 11, 2013 9:38 pm
Do they do KPH?
WD40'll fix it!
If it don't, use a big hammer!
PostPosted: Fri Jan 11, 2013 9:54 pm
Die Die Die!!
PDJ wrote:
Do they do KPH?
I'm waiting to find this out, I have emailed them
PostPosted: Sat Jan 12, 2013 10:31 am
Water pressure sensor is in an adaptor in the top rad hose.
Oil pressure is fed from normal adaptor.
PostPosted: Sat Jan 12, 2013 11:10 am
Die Die Die!!
I received a reply from the company in good time stating the following
We offer the same gauge in kph, but it goes from 0-260.
If you would like the gauge to read 0-160 kph, you can write in "Gauge Notes" under "Current Gauge Attributes" that you would like it to read that speed instead. We will make this change at no extra charge.
PostPosted: Sun Jan 13, 2013 3:02 pm
Some nice looking gauges there which you can customise too.
I presume their packages include both the gauges and the sender/adaptor units?
And the speedometers are electronic?
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Sun Jan 13, 2013 3:51 pm
Die Die Die!!
They include the senders, they sell electronic gauges however I'm looki g at their GPS range, I think they are reasonably priced
