I made a trolley which has four jacks similar style to those on axle stands. Two have sloping tops which fit into the jacking points under the doors, the other two have 10mm diameter pins on top which go into the brackets on the floor at the rear which were used to support the vehicle during manufacture. The front of the trolley is short enough that no interference is there to fit front sub frame, rear is also clear. Trolley is made from 50 x 50 x 1.6mm square tube, used fence posts actually, and fitted with four trolley wheels ex woolies. I could send you some photos if interested, just need your email address.
_________________ John Sneddon 0408 431 807 1963 Morris Cooper 1965 Morris 850 1968 Morris Cooper S
