Rover temp gauge
https://www.ausmini.com/forums/viewtopic.php?f=2&t=79899
Author:  i got a mini [ Thu Jan 10, 2013 3:24 pm ]
Post subject:  Rover temp gauge
These run on 12 volts or do they need a stabilizer ???
Author:  Convertible Mini [ Thu Jan 10, 2013 4:46 pm ]
Post subject:  Voltage stabilizer for Gauges.
Rover instruments do not have a voltage regulator "Externally" like the earlier ones . But looking at the printed Circuits there is a link between the Fuel and Temp Gauges which gives me the impression that there might be a Voltage stabilizer built in to the fuel Gauge like most modern cars. I could be wrong. If you have a cluster out of it's place and you can access the point with a Volt meter you can test what voltage you get at this link with the ignition turned on. If it is less than 12 Volts then there is a built in stabilizer internally.
Author:  i got a mini [ Thu Jan 10, 2013 5:02 pm ]
I'm trying to put a rover 2 clock cluster into a clubman harness
Author:  KLAS [ Thu Jan 10, 2013 5:25 pm ]
they have the stabiliser build in so you can connect them right to your 12V source
Author:  Mini Mad [ Thu Jan 10, 2013 6:32 pm ]
What could be wrong if it works but is reading incorrectly, reads full when full but empty when there is still half a tank.
Author:  i got a mini [ Thu Jan 10, 2013 6:54 pm ]
Fuel gauge works but is not accurate and temp does work at all
Author:  KLAS [ Thu Jan 10, 2013 7:13 pm ]
thats a very common problem, even worse with the latest MPi Rover. thats why they made the sender adjustable and after they didn't adjust it properly from the factory the issued a tech bulletin.
don't know it this helps with your minis.
Author:  Mini Mad [ Fri Jan 11, 2013 3:51 am ]
I have a 97 Japanese SPi - how do you adjust the sender?
Author:  KLAS [ Fri Jan 11, 2013 8:25 pm ]
hope you don't mind the german language
http://allbrit.de/downloads/BULLETINS/Tankanzeige.pdf
Author:  Convertible Mini [ Sat Jan 12, 2013 1:50 pm ]
Post subject:  Grerman?
Das ist alles klar, mein Deutsche is gans gut noch Klas. Danke..
Author:  KLAS [ Sun Jan 13, 2013 7:59 am ]
freut mich wenns hilft
