997 valve springs.
https://www.ausmini.com/forums/viewtopic.php?f=2&t=79904
Author:  haze blue 850 [ Thu Jan 10, 2013 9:48 pm ]
Post subject:  997 valve springs.
Greetings all.
Re-assembling a Cooper 997 head after getting it machined. Measured the spring (s) length, and they are all around 4". The book says they should be 4 & 1/2". Would this effect the performance much?
Alex.
Author:  simon k [ Thu Jan 10, 2013 10:01 pm ]
Assuming you mean they're 4" uncompressed, and not installed in the head, they're either shorter springs than standard, or they've lost 1/2" of springiness. If they've lost springiness, then valve bounce will set in a lot earlier than if they were new
I'd ditch them for newies - good springs are cheap
Author:  haze blue 850 [ Thu Jan 10, 2013 10:08 pm ]
Thanks Simon.
Sounds like a fresh set will make sure all's good.
Alex.
