Fan on backwards https://www.ausmini.com/forums/viewtopic.php?f=2&t=79929 |
Author: | Beanie [ Sat Jan 12, 2013 3:11 pm ] |
Post subject: | Fan on backwards |
ok so i have found my weakness .. i can't for the life of me tell if my fan is on the wright way .. i thought it was fine buyt now after looking at the Cooper on the shannons auction im all confused.. would this explain why the Fan is so noisy ? ![]() ![]() Beanie |
Author: | Harley [ Sat Jan 12, 2013 3:14 pm ] |
The reason its noisy is because its a 4 blade fan. |
Author: | winabbey [ Sat Jan 12, 2013 4:07 pm ] |
There's a nice explanation of the noise levels for the various types of fans here - http://www.minisport.com.au/category3_2.htm |
Author: | drmini in aust [ Sat Jan 12, 2013 6:12 pm ] |
winabbey wrote: There's a nice explanation of the noise levels for the various types of fans here - http://www.minisport.com.au/category3_2.htm
I take exception to the 1st line in that Minisport ad, sure they were designed for Australian conditions: In 1965 we got a new improved radiator with 16 gills (fins) per inch. Was still a 3 core but cooled much better than the previous ones. As for fans, I believe the original 16 blade metal fan on our cars was an Australian design, then adopted by the Poms. IMO it's still the best/quietest for a road car. ![]() Cooper S overheating in traffic? that's a /flame subject for another thread.. ![]() |
Author: | michaelb [ Sat Jan 12, 2013 7:45 pm ] |
I think the four blade fans will only go on one way? And yes they are very noisy. |
Author: | Morris 1100 [ Sat Jan 12, 2013 8:51 pm ] |
Yes, the 4 blade can only go in one way. |
Author: | willy [ Sun Jan 13, 2013 10:30 am ] |
Ditch that noisy thing, sounds terrible! ![]() |
Author: | Beanie [ Sun Jan 13, 2013 12:13 pm ] |
Cheers Guys i was pretty sure that it was correct... but i thought i best just to check .. would a six blade fan be better for air movement ? just trying to chase a heating issue, Beanie |
Author: | Morris 1100 [ Sun Jan 13, 2013 12:22 pm ] |
I would look at whatever is causing the heating issue. The fan is not causing it to overheat. |
Author: | mattsmadmini [ Sun Jan 13, 2013 12:50 pm ] |
For what its worth I love my 4 blade fan, pushes a shiteload of air, noisy? Yep, can I hear it over the sound of a fat Weber and exhaust? Nope ![]() As others said sort the rest of ur cooling first, flush and reverse flush everything, use a good, real coolant (ones that you have to make up are good, little bottle of tectaloy gold is great) well sorted radiator, good working thermostat should make it cooler for ya! |
