It is currently Fri Jul 25, 2025 11:04 am
 Post subject: Leaking Clutch seal
PostPosted: Mon Jan 14, 2013 10:19 pm
Hi guys, I am over trying to stop the clutch seal from leaking.. I have tried 2 times, a specialist has fitted a new one, and still leaking.. So i am thinking of fitting a catch can and just unscrewing it..
Can I helicoil the hole where the oil leaks out, and put a screw in adapter and a bit of hose into a catch can..
Has any one done it before? I just don't want the mini to leak on my nice new floor.. Its only a drop or two occasionally, but it drives me nuts
PostPosted: Mon Jan 14, 2013 10:34 pm
Simple fix: put a piece of plastic down, then a piece of old cut up carboard box on top. Ensure both pieces fit between the wheels of the mini. Change cardboard often.
Clean floor, no more sleepless nights! :P
PostPosted: Mon Jan 14, 2013 10:41 pm
ha ha ha ha NO!!
PostPosted: Tue Jan 15, 2013 4:35 am
So does anyone on here have a mini that does NOT leak? Put your hand up for Brett..
Mine surely does. It is annoying - mostly for my lovely better half.
Alec
PostPosted: Tue Jan 15, 2013 7:25 am
I've got a few galvanized drip trays from supercheap and I put No frills Cat Litter I got for free from work in them. Sooner or later I'll run out of Cat Litter, but it's taken 7 yrs so far.
PostPosted: Tue Jan 15, 2013 8:15 am
Sadly a leaking clutch seal will eventually destroy the clutch plate due to excess oil.
Have you replaced the primary gear as the current one may be worn in the centre bushes and letting oil seep out?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Jan 15, 2013 9:40 am
If you fit a Rover seal protector as well, it acts as a slinger and keeps oil off the clutch plate. Apart from the miniscule bit that seeps through the primary gear bushes- and that gets flung out through the holes in the flywheel and won't get on the plate.
Users browsing this forum: Majestic-12 [Bot] and 95 guests
