may have cooper 998 shell.... how do i tell? https://www.ausmini.com/forums/viewtopic.php?f=2&t=79969 |
Author: | Blunder [ Tue Jan 15, 2013 4:44 pm ] |
Post subject: | may have cooper 998 shell.... how do i tell? |
Ok, help.... It has 7inch discs but has a 1275 a+ fitted.... What tells me its a cooper apart from the plate? Ta guys.... [/u] |
Author: | OnSafari [ Tue Jan 15, 2013 4:53 pm ] |
J hooks for the fresh air heater Mesh grille for fresh air heater duct behind grille 100mph speedo Trim around doors Check the numbers yka2s1 etc. |
Author: | Morris 1100 [ Tue Jan 15, 2013 5:06 pm ] |
Sliding windows No hydro Numbers stamped on the body |
Author: | Blunder [ Tue Jan 15, 2013 5:36 pm ] |
Where would I find number? Could someone give me a pm and call? |
Author: | Blunder [ Tue Jan 15, 2013 5:38 pm ] |
It's got a 64 wiper motor and that plate number, doors have been swapped out and rubber suspension |
Author: | AJ [ Tue Jan 15, 2013 6:23 pm ] |
The car number on the plate , should match the number stamped into the firewall,below the plate , and the number on the radiator shroud if the car number is after about 2000 should be very close to that number . If however its a very late car the radiator shroud number should be around 500 below the car number . Edit : Should have black vinyl covering on top and bottom dash rails,electric fuel pump, if its a 998 Cooper it should also a have nylon breather for fuel pump under left hand side passenger seat (or hole where it was) |
Author: | sgierke [ Tue Jan 15, 2013 6:44 pm ] |
patch over where the 850 gear sticker came throught. at the front of the tunnel. |
