It is currently Mon Jul 28, 2025 3:10 am
PostPosted: Tue Jan 15, 2013 5:22 pm
I just bought some replacement elements for my Ramflos
1. should I use them dry or oiled.
2. they say to wash them before use ?
so what do you reckon?
PostPosted: Tue Jan 15, 2013 6:49 pm
If they are Lynx pads, I'd throw em away and buy Unifilter pads (LNX300 for SU and LNX400 for Weber). These are polyurethane foam, and come pre-oiled ready to fit. Under $10 each.
Lynx ones have more restriction, and catch fire if not oiled (the oil has a flame retardant). They also crumble and fall to bits much sooner.
If you don't oil foam filters they are just rock catchers, as the dust goes through them.
PostPosted: Tue Jan 15, 2013 7:06 pm
I agree with drmini. Listen to him his a doctor. You have to oil them
PostPosted: Tue Jan 15, 2013 7:18 pm
Well I just discovered that the bases are for 1.5 in su not 1.25 in and I have
1.25in the large hole in the middle of the base measures 45 mm, I bought the new elements from mini bits.
PostPosted: Wed Jan 16, 2013 9:11 pm
You can also buy them direct from unifilter up the central coast and they will post them to you; or one of their sydney distributors. There is a listing off their website.
PostPosted: Wed Jan 16, 2013 9:32 pm
http://www.uniflow.com.au/contents/en-us/d141.html
Quicker than trying to find them elsewhere. :wink:
PostPosted: Thu Jan 17, 2013 3:15 pm
So it sounds like they are for 1.5in su yes???
PostPosted: Thu Jan 17, 2013 3:41 pm
Sounds like it if the holes are around 1.5".
If they are new can't you exchange them??
The filter pads are all the same size though.
