Engine exterior paint removal question. https://www.ausmini.com/forums/viewtopic.php?f=2&t=8000 |
Page 1 of 2 |
Author: | supercharged 850 [ Sun Jun 12, 2005 1:39 am ] |
Post subject: | Engine exterior paint removal question. |
Hello all! I am doing a little bit of engine parts clean up..... and quite simply, I am totally sick of using the wire wheel in my drill. It just doesnt work too well. I have only done the clutch cover at the moment... and its a pretty crappy effort too. The wire wheel just doent get into the corners all too well. I am just wondering what the preferred method is when it comes to stripping all the crap off bits like the clutch cover, flywheel surround, gearbox casing and the block. A high pressure hose wouldnt really do it.... but paint stripper?? Is this safe?? Or what else can I do to get these back to bare metal???? |
Author: | Wombat [ Sun Jun 12, 2005 10:25 am ] |
If you want to get real picky and get right into the tight corners get a Dremil or one of the cheap $20 look a likes from Bunnings. - good on carbies and the like. |
Author: | 1310/71 [ Sun Jun 12, 2005 11:12 am ] |
Post subject: | Re: Engine exterior paint removal question. |
supercharged 850 wrote: Hello all!
I am doing a little bit of engine parts clean up..... and quite simply, I am totally sick of using the wire wheel in my drill. It just doesnt work too well. I have only done the clutch cover at the moment... and its a pretty crappy effort too. The wire wheel just doent get into the corners all too well. I am just wondering what the preferred method is when it comes to stripping all the crap off bits like the clutch cover, flywheel surround, gearbox casing and the block. A high pressure hose wouldnt really do it.... but paint stripper?? Is this safe?? Or what else can I do to get these back to bare metal???? I'd try paint stripper, leave it in the sun for an hour, then hit it with a high pressure hose. |
Author: | Morris 1100 [ Sun Jun 12, 2005 3:54 pm ] |
Sand blaster. ![]() |
Author: | Stuwey [ Sun Jun 12, 2005 9:20 pm ] |
Post subject: | . |
I bead blasted all my aluminium- clutch cover, flywheel housing, and then painted them with VHT Engine Enamel - "Universal Aluminium". Came up a treat. ![]() You may just have to scrape the first chunky bits off the block, but that stipply finish hides most of it. |
Author: | supercharged 850 [ Mon Jun 13, 2005 12:23 am ] |
Ah... cool cool cool..... Stuwey... who's bead blaster did you use?? I was gonna ask ya on Saturday but you left there in a bit of a hurry ![]() |
Author: | J_A_M [ Mon Jun 13, 2005 8:00 am ] |
I sand blasted the alloy stuff and used paint stripper and a wire brush on the cast iron. A bit messy I have to say ![]() |
Author: | Chris [ Mon Jun 13, 2005 10:55 am ] |
It depends. If you are rebuilding the motor send the block to an engine reconditioner and he will put it in the cleaning tank and there will be no paint on it when you get it back. The other simple way if you have not got a bead blaster is make up a bath of caustic soda (draino) and leave the parts in this. Cheaper than paint stripper and you can make the stuff as you need it. We use it to clean mufflers on karts and it takes all the paint off them and all the oil and grease. Use all relevant safety equipment to protecxt eyes etc. |
Author: | drmini in aust [ Mon Jun 13, 2005 11:36 am ] |
If you use caustic, I'd keep it away from the cam bearings, or alloy parts... ![]() |
Author: | Chris [ Mon Jun 13, 2005 9:04 pm ] |
Any bath will stuff the cam bearings. You can use it on alloy with care. Paint stripper would be worse. With caustic you can dilute to suit, try it on a bit of alloy that is not seen. If all else fails buy a bead blaster. |
Author: | Morris 1100 [ Mon Jun 13, 2005 9:14 pm ] |
Take a look at these pics to see what you can do with soda blasting.... http://community.webshots.com/photo/100563359/105661338nGQzWl Just click on the next button to see the rest. |
Author: | Stuwey [ Mon Jun 13, 2005 9:15 pm ] |
Post subject: | . |
My grandpa has one- Its big enough to put an entire motorcycle frame into. The fine glass beads give a really good finish, but the raw alloy stains really easy with grease and oil. Go the silver paint afterwards. |
Author: | FatMaserati [ Mon Jun 13, 2005 9:43 pm ] |
Morris 1100 wrote: Take a look at these pics to see what you can do with soda blasting....
Oh BABY! My Weber is so gonna get some of that. My one at the moment looks all stained and brown and unflattering. Any idea how much it costs to get done? |
Author: | Chris [ Tue Jun 14, 2005 11:31 am ] |
You couldn't ask for better results than that. |
Author: | MiniK [ Tue Jun 14, 2005 1:47 pm ] |
http://community.webshots.com/photo/100563359/105661338nGQzWl Just click on the next button to see the rest. Very tidy indeed...have to give that a go when the time comes |
