Auto to Manual
https://www.ausmini.com/forums/viewtopic.php?f=2&t=80013
Author:  Gongrat [ Sun Jan 20, 2013 12:12 am ]
Post subject:  Auto to Manual
Hi, I am converting my 70' mini-matic to manual and need guidance on cutting the hole for the remote change gear-stick, I don't want to butcher my floor and cut the hole in the wrong place! and not keen on installing the engine/gearbox only to cut the hole then remove again for the spray-job, if you know what I mean. Is there any templates, or measurements any one can give, I.E width from doors, or firewall. width length of hole. any help appreciated.
Will be installing an 1100S with 4 synchro box, and remote shifter, Hardy spicer driveshafts from the matic.
Thanks.
Author:  drmini in aust [ Sun Jan 20, 2013 9:13 am ]
Why not borrow an old remote box and extension, sit it in there with 2 engine mounts on and you can not only see where the hole goes, but position the rear mount bracket in the tunnel.
Author:  Gongrat [ Sun Jan 20, 2013 11:02 am ]
Great idea, thanks Dr. I have engine and gearbox separate. will do.
