It is currently Sat Aug 02, 2025 2:37 am
PostPosted: Wed Jan 23, 2013 8:43 am
Check out this engineering pornography:
http://www.med-engineering.co.uk/catalo ... rocker-set
LD Version:
http://www.med-engineering.co.uk/catalo ... ld-rockers
So anyone using these over the cheaper Minisport version? I have a set of minisport 1.3 roller tips now and these aren't much more expensive and seem like a better designed unit overall. Thoughts?
PostPosted: Wed Jan 23, 2013 9:31 am
The first thing I notice is the "uprated" shaft. I would have thought a larger diameter shaft would mean more friction between the shaft and the arm, because of the greater surface area.
1.5 is pretty high.
PostPosted: Wed Jan 23, 2013 9:48 am
Yeah I thought so too but I think they are full roller rockers which isn't necessarily a good thing, all of the weight and pressure is pushed onto a couple of roller pins instead of the entire bush surface area. By making the shaft bigger it could reduce the stress and spread it across more than 1 or 2 pins?
[EDIT] I stand corrected, they aren't full roller rockers, only roller tip.
1.5's is what I had originally in the car and want to go back for that extra top end power.
PostPosted: Wed Jan 23, 2013 9:56 am
I'd like to know from anyone who has a set if
1) the ratios are uniform across all 8 rockers
2) if there is any play beyond 1 thou or so in the bushes themselves (ie. How good is the manufacturing fit and finish
PostPosted: Wed Jan 23, 2013 1:39 pm
Lillee,
I have been told by a bloke who bought (then immediately sold) some, that there are NO bushes in these MED rockers. See PM I sent you.
[edit] They are made from a pretty hard aluminium alloy, `maybe' bronze bushes are not needed??
The cams in my Fiat 124 sport ran direct in the alloy cam boxes, which didn't wear in the 250,000 miles I drove it for..
Last edited by drmini in aust on Wed Jan 23, 2013 6:23 pm, edited 1 time in total.
PostPosted: Wed Jan 23, 2013 1:57 pm
Yeah stuff that then! So Minisport versus minispares roller tip rockers? Anyone have the minispares edition?
http://www.minispares.com/product/Class ... +to+search
PostPosted: Wed Jan 23, 2013 2:48 pm
Why Not run the Swiftune Rockers ..
Made By Titan bush on the shaft and rollers on the Nose ..
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Wed Jan 23, 2013 2:55 pm
I was looking for them but it's not on their website anywhere? They don't do them anymore or what?
PostPosted: Wed Jan 23, 2013 3:13 pm
GR gets them from Nick Swift. :wink: Not cheap...
PostPosted: Wed Jan 23, 2013 5:32 pm
GR gets them from nick Swift. :wink: Not cheap...
Wow, they must be good!!
:shock:
PostPosted: Wed Jan 23, 2013 7:50 pm
I never met somebody who had to tear an engine down because of side loading on valves......but know of at least two who had to because of disintegrating roller rockers....
How many sets of valve guides can you have fitted for the price of roller rockers?
PostPosted: Thu Jan 24, 2013 8:00 am
Unfortunately there's more to it than that smac... pm me if you are interested
I will let you know what I eventually find out and decide in the next few weeks
PostPosted: Thu Jan 24, 2013 8:58 am
ooooo...is it a secret?! :wink:
If you've got something relevant, why not post it? :roll:
PostPosted: Thu Jan 24, 2013 9:35 am
might stirr up too much controversy. You know me, I aint an abrasive type :P
