It is currently Sun Jul 27, 2025 3:54 am
PostPosted: Thu Jan 24, 2013 6:14 pm
I bought a titan belt drive and bought an MED damper for a spare engine i am building,but guess what - the MED damper does not fit..... Does anyone know if the mini spares two piece cooper s damper can be used with the titan belt drive ? If not what have others with the belt drive used ?
PostPosted: Thu Jan 24, 2013 6:30 pm
Can't fit in what way? I'm not familiar with any belt drive kits.
The MED damper is pretty much just a cooper S damper so i doubt it will fit any different.
PostPosted: Thu Jan 24, 2013 6:38 pm
I run 2 belt drive kits, most recently fitted 1 has an MED damper the other a 1275 one.
What doesn't fit?
[edit] I may have relieved the engine mount support bracket a bit for the MED one, I can't remember now.
 Post subject: Belt drive Kits.
PostPosted: Fri Jan 25, 2013 8:02 am
I have used Trigger Belt drive Kits on my cars for over 28 years. I also have a stock of spare belts for them if any one needs any. I have also used standard 1275 Harmonic Balancers. Never had a problem fitting them.
"Let us remove your "SHORTS"
Users browsing this forum: JM1275 and 86 guests
