Damper to use with Titan Belt drive kit https://www.ausmini.com/forums/viewtopic.php?f=2&t=80078 |
Author: | douglas42l2 [ Thu Jan 24, 2013 6:14 pm ] |
Post subject: | Damper to use with Titan Belt drive kit |
I bought a titan belt drive and bought an MED damper for a spare engine i am building,but guess what - the MED damper does not fit..... Does anyone know if the mini spares two piece cooper s damper can be used with the titan belt drive ? If not what have others with the belt drive used ? |
Author: | mini_mad_matt [ Thu Jan 24, 2013 6:30 pm ] |
Can't fit in what way? I'm not familiar with any belt drive kits. The MED damper is pretty much just a cooper S damper so i doubt it will fit any different. |
Author: | drmini in aust [ Thu Jan 24, 2013 6:38 pm ] |
I run 2 belt drive kits, most recently fitted 1 has an MED damper the other a 1275 one. What doesn't fit? [edit] I may have relieved the engine mount support bracket a bit for the MED one, I can't remember now. |
Author: | Convertible Mini [ Fri Jan 25, 2013 8:02 am ] |
Post subject: | Belt drive Kits. |
I have used Trigger Belt drive Kits on my cars for over 28 years. I also have a stock of spare belts for them if any one needs any. I have also used standard 1275 Harmonic Balancers. Never had a problem fitting them. |
