It is currently Thu Jul 24, 2025 1:12 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
PostPosted: Wed Jan 23, 2013 10:26 pm
As above, do they have a part number / ID on them?
How do you identify one?
Thanks.
Now with 2 extra ports!
PostPosted: Thu Jan 24, 2013 7:53 am
If you are talking the rear pressure limiting valve (it is NOT a bias valve) the valve is the same as all the common Oz Minis (with single line MC), only the spring is different.
There is really not a lot of difference in the limiting pressure between models, these days if you have one that still works, use it.
I'd like to fine some repair kits though... :cry:
You can convert them all to be limit adjustable, I did one for Mini_Mad a while back.
PostPosted: Thu Jan 24, 2013 8:18 am
http://www.ebay.com.au/itm/NOS-MINI-K-M ... 3f21617997
PostPosted: Thu Jan 24, 2013 8:36 am
i`m pretty sure they were a different cyl all together,,, smaller & also a different seal kit & spring
i`ll double check but that`s what i remember them to be
SSB602 & SSB603 were the kit numbers from memory
i`ll do my homework before i open my big gob any further tho :-)
PostPosted: Thu Jan 24, 2013 10:31 pm
So I'll try to post the part number that's on mine tomorrow. You would think BMC would put a different part number on the limiting valve if the internals were in fact different? Any one have a reference book with a part number to confirm this. Unless I pull a few apart to look at spring lengths you don't know what you have...
PostPosted: Fri Jan 25, 2013 6:32 am
From PUB1038 Mini K parts book-
Mini K limiting valve assembly is 4313/755
repair kit is SSB802
Sorry I have no listing on the S one.
However when Karcraft sold the Lockheed repair kit (now NLA) there was only 1 kit. I believe only the internal spring was different.
PostPosted: Fri Jan 25, 2013 7:22 am
The Mini King
Thanks.
A Cooper S Valve will have two (2) grooves machined into the round section of the main body Non Cooper S will have no grooves at all, The diff between them is the spring tension
PostPosted: Fri Jan 25, 2013 7:42 am
Thanks Kev and John for the good info. That will all help.
Cheers.
PostPosted: Fri Jan 25, 2013 8:50 am
The parts books confirm what John said above (did anyone doubt it!) although there's no mention of the rings on the body to identify the two types.
The MK II Mini parts book (PUB 1056M) and the Mini Clubman parts book (PUB 1052) show the same part numbers for the body, plug, plunger and washer for all Minis, but the spring for the Cooper S/Clubman GT is part 3111/671 (400 - 450 lbs) and for other models part 3111/673 (350 - 400 lbs).
The valve repair kit doesn't contain a spring so it's the same for all models - part SSB802.
PostPosted: Fri Jan 25, 2013 11:09 am
ah well,,, there you go,,, i was close,,, my memory isn`t what it used to be :-) nearly tho :-)
now,,, why have i got it in my head that there are 2 different bodys then???,,, small & large,
I`ll ask dad later on, he`ll know :-)
PostPosted: Fri Jan 25, 2013 12:16 pm
PostPosted: Fri Jan 25, 2013 12:35 pm
The Mini King
TheMiniMan wrote:
Hi Matt I am Fairly sure the one on the right is Morris 1100
PostPosted: Fri Jan 25, 2013 12:39 pm
TheMiniMan wrote:
Thanks Matt, so both those are Non Cooper S.
Does anyone have a pic of an S one with the rings?
We are getting closer....
PostPosted: Fri Jan 25, 2013 2:15 pm
I crawled under my MK II Cooper S's to take these. Can't see any obvious rings (except around the flange under the big nut) but maybe someone else can.
PostPosted: Fri Jan 25, 2013 2:38 pm
Great pics, thanks for your efforts!
Probably hard to read any numbers on it..........
